Phil G4SPZ
I’ve just acquired this clock, which matches Plate 1521 in the Tenth Edition of the Guide, but is definitely a midget and requires a new Horolovar no.44 suspension unit, as the fork and bottom block are missing too.
While this is on order, I’ve dismantled the clock to clean it. I have found that the anchor pin is bent, as is one of the pallet pins; the pallet pin nearest the camera has a distinct upward tilt. I’m sure that pallet pins should be dead straight, so with great care I propose to try to straighten it. However I’m not sure whether the anchor pin should be bent or straight - it’s conceivable that this shape is actually correct.
If not, why would anyone do such a thing? Is it my bad luck, or has every clock out there been ‘got-at’ by someone before me? I seem to get more than my fair share!
This is my first pin-pallet 400 day escapement, so any advice from more experienced practitioners would be much appreciated. Many thanks,
Phil
Phil
