Rust removal by electrolysis, a Cuckoo Clock example
chrisuk
Sep 4, 2010
95
Staffordshire , UK
I cleaned up this cuckoo clock a few years ago and used electrolysis to clean the steel parts.
Movement, Regula 01, marked Made in Germnay, US Zone.
From the back, LH has winding ratchet with square-cut teeth, RH has coiled spring.
Count wheel outside the plates, pin wheel between them. Strike lifting piece outside the front plate.
No centre shaft, the hands are mounted on a stud fixed to the front plate.
It takes more than a six foot chain to run for a day, two metres would be enough.
From the front, LH chain 63 links/ft, correct, RH 58 links/ft, winds roughly.
Overall case height 16".
DRGM on the locking/warning lever.
The MB mentions various sites giving details regarding the use of electrolysis for rust removal but the 'tiscali' one no longer exists. This one does www.qsl.net/2e0waw/rust.htm.
There was rust on all the steel parts and general debris everywhere. The case was sticky with residues of tobacco smoke. The bellows had a few remnants of leather.
Here are some before and after photos.
I already had a bench power supply with a constant current facility so it was easy to perform the cleaning.
R&A
Oct 21, 2008
4,203
107
Electrolysis is used in many application.
46,916
1,987
We've had some discussions in this forum on how to do it. Use search if curious.
bangster
19,984
510
Hint: Search on "electrolyte". You'll get more hits.
chrisuk
Sep 4, 2010
95
Staffordshire , UK
Thanks to you all. Obviously I wasn't being entirely clear. I've used electrolysis for cleaning quite often and was just posting an example of how effective it is, together with the URL of a site which gives details of how to do it.
166,999
1,455,306
87,234
Brian Cooney
