Runs and Stops Runs and Stops...
64mustang
Dec 12, 2010
32
This is a project for a friend....circa 1980 Japanese replica of a European wall clock...runs well for 30 seconds then I can see the pendelum falter slightly then it slows to a stop. Repeats itself consistently.
I don't think it was ever cleaned. The bushings (pivots?) had black crystalized old lube in them. Tried to clean them the best I could and
re-oil.
What's next? Thanks in advance for helping.
Kevin W.
23,098
529
64 i think you have the answer.Dissasemble clean and oil.That way you have eliminated many possibilities of why it wont run.
46,431
1,861
If you can see the pendulum falter, I'd suspect a problem with the escapement. Perhaps the anchor is hitting a tooth. Can you provide pictures?
Talyinka
May 14, 2011
650
10
England
Take a close look at the escape wheel and also on the pallets, looking for excessive wear, bent or worn cogs, etc.
I think Veritas has the right idea. Troubleshooting a clean movement is a lot easier than troubleshooting a dirty one, especially if you carry out a close inspection of all parts as you disassemble the movement, and after cleaning.
RJSoftware
Apr 15, 2005
8,480
122
Loxahatchee, Florida
First thing I do is check the beat.
Lean your clock till she ticks with pride, then adjust her crutch to that high side.
RJ
64mustang
Dec 12, 2010
32
Thank you all very much. I was looking for crud in the bushings but after reading Bangster's beat balance 101, I went to the crutch and that was it. A little straightening and she runs non-stop and in beat balance.
This is a fantastic website !
Thank you all again.
bangster
19,951
485
RJ
Never been able to learn Arjay that "lean" is an intransitive verb. Its transitive counterpart is "tilt".
:D:D:Party:
Kevin W.
23,098
529
It may be running now but if you wish to run the clock all the time.It should be properly cleaned.Running it this way will just make more wear.
Just trying to state what may happen.:)
165,498
1,440,653
86,269
Nacht Kreatur
2,873
