Runs a tiny bit fast... bob is as low on the pendulum as possible.
Discussion in 'General Clock Discussions' started by trschaefer, Jan 11, 2018.
  1. trschaefer
    trschaefer Registered User
    Feb 20, 2017
    Accountant
    Madison, WI
    I just got this weight driven banjo clock on eBay. Seller warned me that it ran a little bit fast. So I've got the bob as low as possible on the pendulum that came with the clock. He was right... It gains about 5 minutes after about 4 or 5 days. I know there is some mathematical formula (which I'd rather avoid...) for determining the correct pendulum length for a specific clock movement. I was just wondering if there was anything else I could try "short" of getting a "longer" pendulum rod... The clock case could accommodate a slightly longer pendulum rod. Does the weight of the bob have any impact? Probably not... The clock has not stopped running since I hung it up a about a month ago. So everything else seems fine. Thanks.
  2. bruce linde
    bruce linde Technical Admin
    NAWCC Member Donor
    2,144
    20
    web developer
    oakland, ca.
    assuming all original, the bob would ideally be centered in the viewing window of the bottom tablet... and it looks kind of low to me, as is.
    have you had the hands and dial off to see what's under the hood? maybe some of the original pics from when you bought it?
  3. THTanner
    THTanner Registered User
    NAWCC Member Sponsor Donor
    Jul 3, 2016
    1,266
    20
    Carson City, Nevada
    a clock that is out of beat will sometimes run too fast as the pendulum short cycles. Try setting the beat really well and see if your clock is affected this way.
  4. leeinv66
    leeinv66 Super Moderator
    NAWCC Member Donor
    Mar 31, 2005
    8,111
    13
    Industry Specialist
    Launceston Tasmania
    Longer suspension rod will be the likely cure. You could try a thinner suspension spring, but that is probably the same amount of work as making a longer rod.
  5. Willie X
    Willie X Registered User
    8,434
    69
    Placing a thin strip of lead (about
    1/4 ounce) at the top - back of the pendulum bob will do it. You can secure it with a dab of E-6000 or double sided tape.
    Many of these have a keystone type suspension assembly. It's common for the old suspension spring to have been broken off and repaired. So, your cure could be as simple as restoring the suspension spring to its proper length.
    IMOE, the clock makers back then weren't so particular about the position of the pendulum. Lower was more prevalent than higher and only a few were exactly where you would think they should go.
    trschaefer likes this.
  6. THTanner
    Jul 3, 2016
    1,266
    20
    Carson City, Nevada
    Since it is running too fast, would you not want the added lead at the bottom - back of the bob ?
  7. shutterbug
    shutterbug Super Moderator
    35,165
    72
    I'm with the opinion that the spring probably broke and was put back on. A new suspension rod and spring is the likely best solution. All of the usual suppliers have them.
  8. Willie X
    8,434
    69
    Correct-amoondo, lead strip near the bottom. Listen to THT.
    Willie
  9. leeinv66
    NAWCC Member Donor
    Mar 31, 2005
    8,111
    13
    Industry Specialist
    Launceston Tasmania
    Not sure that will such a slow it down considering the size of the bob and hence the size of the lead strip you could hide on the back of it.
  10. THTanner
    Jul 3, 2016
    1,266
    20
    Carson City, Nevada
    I don't usually comment on Willie's posts, but when I do I send him Dos Equis ;)
  11. trschaefer
    Feb 20, 2017
    Accountant
    Madison, WI
    Great. Now I've got a few ideas of where to go with this problem. Thanks.
  12. novicetimekeeper
    Jul 26, 2015
    5,373
    36
    Dorset
    You seem to have some diametrically opposed ideas on offer.
    If you want to change the rate by adding a small mass to the back of the bob, adding it at the bottom will slow it down, adding at the top will speed it up.
    Great Clock facts
  13. harold bain
    NAWCC Fellow NAWCC Member Donor
    40,504
    76
    Hope he has room for horses.....
    THTanner likes this.
  14. shutterbug
    35,165
    72
    Not always. To speed the clock up, you need to add weight above the center of oscillation. With many suspension-wire-and-bob clocks, the top of the pendulum might get it done. With the more complicated lyre pendulums, above the bob will still slow it down, but not as much.
  15. novicetimekeeper
    Jul 26, 2015
    5,373
    36
    Dorset
    looks a pretty conventional pendulum setup to me.
  16. THTanner
    Jul 3, 2016
    1,266
    20
    Carson City, Nevada
    This is true for Lyre pendulums - and perhaps some others. I am currently experimenting with a lyre pendulum for a "94 cm" Urgos movement. While the lyre assembly is about 34 inches long, the center of gravity according to a balance method is about 3 inches above the bob. So adding weight to the top of the bob will slow it down some. Adding weight to the bottom of the bob will slow it down more using the same amount of weight. On those Lyre pendulums it is amazing how much top weight is in those decorative rods, some of which are steel on this Lyre.
  17. Bill Ward
    Bill Ward Registered User
    Jan 8, 2003
    1,214
    EE (spec. acoustics) now medicine
    USA
    Very nice clock! If 'twer mine, I'd clean it first- insufficient amplitude makes a clock run faster due to circular error. Next, I'd look at the escapement carefully while running- could it be skipping any teeth? Are all the teeth straight & of even length? Is the beat even throughout the rotation of the escape wheel? Then I'd look at the suspension spring- they are commonly damaged by clueless owners or movers. (Yesterday, a friend told me of a house guest who, unable to sleep because of a heavy marble clock's quarterly chiming, and unsure how to stop it, moved it in the middle of the night into the basement!) Of course, it's always possible that a dealer put on another clock's pendulum.
Similar Threads - Runs tiny fast Forum Date
precision regulator runs slightly faster in extreme heat... ?!? General Clock Discussions Sep 11, 2017
Tiny Cuckoo Clock General Clock Discussions Jul 31, 2017
cuckoo clock looks like a 8 day but runs like a 1 day???? General Clock Discussions Jun 12, 2017
Seconds Hand on Antique longcase runs backwards, was it a modification? General Clock Discussions Jan 10, 2015
Antique E Ingraham Company Mantle Clock circa 1889 runs fast General Clock Discussions Aug 26, 2014
