richiec
Being a newbie to ultrasonic cleaning about how long doe you leave parts in the cleaner? I am using L&R ultrasonic cleaner. Then how do you remove the cleaner from the parts and dry them?
I don't have any beakers but do have small jelly jars which I hope aren't too thick for this purpose
Generally, two to four minutes.Being a newbie to ultrasonic cleaning about how long doe you leave parts in the cleaner? I am using L&R ultrasonic cleaner.
To dry: Bergeon 5733 hand blower (or similar), hair dryer, watch parts dryer, etc. Pretty much anything that dries w/o magetizing.Then how do you remove the cleaner from the parts and dry them?
Inbetween those two steps, the parts must be rinsed as Graham pointed out.
I reckon it probably will, but may not rinse as efficiently as a rinse made for use in ultrasonics. My grandfather, a master watchmaker, used to clean parts at home by boiling for ~ 10 minutes in water with a bit o' ammonia and a few drops of dish soap. He'd rinse in distilled water, dry them with a lint-free cloth and reinstall.The regular rinse solution won't work with the ultrasonic?
I have lots of regular rinse just want to know if it is compatible with the ultrasonic.
