Rules and SOP
Discussion in 'Encyclopedia (Wiki) Help' started by kirxklox, Jun 30, 2009.
  1. kirxklox
    kirxklox Registered User
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    Where are the rules and SOP for the WIKI?
    What about the COPYRIGHTS?
  2. Tom McIntyre
    Tom McIntyre Technical Admin
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    The policies are in development and will be published for comment soon.
  3. Tom McIntyre
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    The operating rules for the NAWCC Encyclopedia have been published in the Tutorials section of the Encyclopedia.
    The articles are:
    • [MAIN]Purpose of the NAWCC encyclopedia[/MAIN]
    • [MAIN]Copyright of text in NAWCC Encyclopedia Articles[/MAIN]
    • [MAIN]Copyright of images in the NAWCC Encyclopedia[/MAIN]
    • [MAIN]Writing and Editing Encyclopedia Articles[/MAIN]
    Comments on the technical accuracy of the articles are welcome in the comments tab of the articles.
    Comments and discussion of the implicit NAWCC business practices should be made in the NAWCC Members Only area.
  4. kirxklox
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    I would like to inform you that you are Shutting Down IE on the Wiki Articles.
  5. Tom McIntyre
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    Thanks for the bug report Sam. The problem is now fixed.
  6. kirxklox
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    I only crashed IE 20 times last night.
  7. Tom McIntyre
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    There is a bug in ie8 with larger Javascript execution. The Encyclopedia software has been modified to work around the bug.
    It occurred when one clicked on the Java based tabs when viewing an article to post a comment, look at history, edit, etc.
    We can run the software without Javascript, but the performance is generally better with it enabled.
  8. kirxklox
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    I do not have IE 8 installed only IE 7.
    What JAVA?
  9. Tom McIntyre
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    special_reset.js
  10. kirxklox
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    That is not JAVA! Must be a syntax error.
  11. Tom McIntyre
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    Sam, did you read the file? It does not display particularly well here, but here it is.
    Code:
     * CES Vault Wiki
     * Version 2.3.1
     * Copyright ©2008-2009 Cracked Egg Studios. All Rights Reserved.
     * This file may not be redistributed in whole or significant part.
     * VAULTWIKI IS NOT FREE SOFTWARE
     * http://www.crackedeggstudios.com/vault/The-Arsenal:CES-VaultWiki
     * http://www.crackedeggstudios.com/vault/VaultWiki-License-Agreement
    // vB_ResetHandler
    function vB_ResetHandler()
    	// handles adding of JS and CSS
    * Process HTML after a redirect
    * @param	ajax	response
    * @param	string	article URL
    vB_ResetHandler.prototype.parseRedirect = function(ajax_response, thread_url)
    	var splitter = thread_url.indexOf('?') != -1 ? '?' : '&';
    	var articleResponse = fetch_tags(ajax_response, "article")[0];
    	if (articleResponse.getAttribute("reload") == "1")
    		window.location = thread_url.split(splitter + "do")[0];
    		return true;
    	var tabResponse = fetch_tags(ajax_response, "tabs")[0];
    	if (!tabResponse || !tabResponse.firstChild)
    		return false;
    	this.insertPoll(ajax_response);
    	// we had an article redirect, destroy all tabs
    	YAHOO.util.Dom.get(tab_container).innerHTML = tabResponse.firstChild.nodeValue;
    	var tabId = articleResponse.getAttribute("tab_id");
    	YAHOO.util.Dom.get("collapseobj_" + tabId).innerHTML = articleResponse.firstChild.nodeValue;
    	// re-init tabs in case permissions or article status changed
    	ajax_load_url[tab_container] = thread_url;
    	if (vB_WikiTabs)
    		if (vB_WikiTabs[tab_container] && vB_WikiTabs[tab_container].overflow_tab)
    			var overflow_html = vB_WikiTabs[tab_container].overflow_tab.innerHTML;
    		else
    			var overflow_html = "»";
    		vB_WikiTabs[tab_container] = new vB_WikiTab(tab_container, tabId, overflow_html);
    	return false;
    * Dynamically parses Javascript
    * @param	object	tab
    * @param	object	popups
    vB_ResetHandler.prototype.parseScript = function(cobj, popups)
    	var dropdowns = cobj.getElementsByTagName("script");
    	var tabId = cobj.getAttribute("id");
    	if (tabId != "forum_header")
    		tabId = tabId.split("collapseobj_")[1];
    	if (popups)
    		var existpop = YAHOO.util.Dom.get("popups_" + tabId);
    		if (existpop)
    			existpop.parentNode.removeChild(existpop);
    		if (popups.firstChild)
    			var popdiv = document.createElement("div");
    			popdiv.setAttribute("id", "popups_" + tabId);
    			popdiv.innerHTML = popups.firstChild.nodeValue;
    			document.body.appendChild(popdiv);
    			// dropdowns.concat doesn't work?!
    			var drop2 = popdiv.getElementsByTagName("script");
    			if (drop2.length)
    				for (var p = 0; p < drop2.length; p++)
    					dropdowns[dropdowns.length] = drop2[p];
    	if (dropdowns.length)
    		var i, dropHTML;
    		for (var i = 0; i < dropdowns.length; i++)
    			if (dropdowns[i].getAttribute("type") != "text/javascript")
    				continue;
    			if (dropdowns[i].getAttribute("src"))
    				this.include(dropdowns[i].getAttribute("src"));
    			else if (dropdowns[i].innerHTML)
    				if (typeof PHP != "object")
    					return false;
    				dropHTML = PHP.trim(dropdowns[i].innerHTML);
    				if (dropHTML.substring(0, 4) == "<!--")
    					dropHTML = dropHTML.substring(4);
    				if (window.execScript)
    					window.execScript(dropHTML);
    				else
    					window.eval(dropHTML);
    * Dynamically includes a Javascript file
    * @param	string	javascript HTTP-path
    vB_ResetHandler.prototype.include = function(scriptpath)
    	var oXML = this.getXMLHttpObj();
    	if (!oXML || !scriptpath)
    		return false;
    	oXML.open("GET", scriptpath, false);
    	oXML.send("");
    		window.execScript(oXML.responseText);
    	else
    		window.eval(oXML.responseText);
    * Fetch the request object for a JS include.
    * @return	object	XMLHttpRequest || ActiveXObject
    vB_ResetHandler.prototype.getXMLHttpObj = function()
    	if (typeof XMLHttpRequest != "undefined")
    		return new XMLHttpRequest();
    	var i,
    		axO = [
    			'Msxml2.XMLHTTP.6.0',
    			'Msxml2.XMLHTTP.3.0',
    			'Msxml2.XMLHTTP',
    			'Microsoft.XMLHTTP'
    	for (i = 0; i < axO.length; i++)
    		try
    			return new ActiveXObject(axO[i]);
    		catch (e)
    	return null;
    * Add stylesheets for new tabs.
    * IMPORTANT: Only use absolute URLs in @imports!
    * @param	string	CSS Text
    vB_ResetHandler.prototype.appendCSS = function(insertStyle, rulePos)
    	if (!YAHOO.util.Dom.get("vw-custom"))
    		var style2 = document.createElement("style");
    		style2.id = "vw-custom";
    		style2.type = "text/css";
    		if (style2.styleSheet && is_ie)
    			var importPaths;
    						while (importPaths = insertStyle.match(/@import url\(\"(.*)\"\);/))
    							document.styleSheets[document.styleSheets.length - 1].addImport(importPaths[1]);
    							insertStyle = insertStyle.replace(importPaths[0], '');
    			style2.styleSheet.cssText = insertStyle;
    		else
    			style2.appendChild(document.createTextNode(insertStyle));
    		document.getElementsByTagName("head")[0].appendChild(style2);
    * Insert the HTML for a poll.
    vB_ResetHandler.prototype.insertPoll = function(ajax_response)
    	var pollResponse = fetch_tags(ajax_response, "poll")[0];
    	if (pollResponse)
    		var pollobj = YAHOO.util.Dom.get("collapseobj_ca-poll");
    		if (pollobj)
    			pollobj.innerHTML = (pollResponse.firstChild ? pollResponse.firstChild.nodeValue : "");
    // initialize the resetter
    var vB_ResetHandle = new vB_ResetHandler();
     * Downloaded: 20:59, Thu Jul 9th 2009
     * Licensed to: https://mb.nawcc.org
  12. kirxklox
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    Tom: You called it JAVA, but it is JavaScript wich is an entirely dirfferent beast.
  13. Tom McIntyre
    Aug 24, 2000
    82,503
    1,563
    176
    retired SW dev
    Boston
    Gee Sam, the term Javascript is used twice to make it clear what the tool is.
    The file extension was .js, which I thought also made it clear.
  14. kirxklox
    Dec 17, 2002
    4,387
    56
    Dardanell, AR
    Gee, That is the KIND of nitpicking that is going on about my TYPO errors.
