Rotary. wrist watch
Discussion in 'Wrist Watches' started by Fenner, Apr 5, 2017.
  1. Fenner
    Fenner Registered User
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    Would anybody be able to shed a light on the Quality and age of a Rotary wrist watch said to be quite old the serial no of the watch on the inside of the back plate is marked SD and then below it is 8006. The case is marked .9.375 with an "r" and a plain "shield" I was trying to find out the model of the watch but could not find any info online and there is no numbers on the movement itself only the name Rotary. Any help would be appreciated. I can forward Photo's if necessary. Fenner
  2. glenhead
    glenhead Registered User
    Nov 15, 2009
    816
    11
    Telecom Engineer
    Williamson County, Texas
    Wow, this post has been up for two hours and you haven't yet been scorned and mocked for a lack of photos. We really do need a couple of pictures to be able to help the best, please.
    Glen
  3. Fenner
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    Sorry about that There is nothing on the back of the watch to photograph.
    [​IMG][​IMG]
  4. JTD
    JTD Registered User
    Sep 27, 2005
    4,053
    23
    There may be nothing on the back but if you took it off, we could see the movement.
    JTD
  5. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,945
    watchmaker
    Western NSW, Australia
    The movement will likely be an ETA 1080.
  6. Fenner
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    JTD Thanks for your reply. I had the back off and just took the details I have given but I had an hell of a job to get the Back on, the glass was loose (whether it is designed to be ) I don't know then eventually got it back and noticed as you probably did the "7" pip had come off so I took the back off once again and put the "7"pip back and then another 1/2hr to try and get the back on again so a little reluctant to take it off. However, if you cannot give me any info in the state its in I will once again remove the back. I would not have thought the glass would be loose as most watches by Rotary ( I thought) would be waterproof to a certain depth.
  7. JTD
    JTD Registered User
    Sep 27, 2005
    4,053
    23
    Sorry to hear how difficult it was to remove the back. Roughbarked has given you a lead to the movement, so perhaps you won't need to take it off again. Someone else may have more detailed information.
    JTD
  8. gmorse
    gmorse Registered User
    7,303
    26
    Retired from Xerox
    Hi Fenner,
    The case appears from your description of the marks to be 9 carat gold, and if the "r" is a date letter, that suggests 1972, (if it has London hallmarks), which ties in with the style of it. The crystal certainly shouldn't be loose, even if it isn't claimed to be "water resistant", (cases like this were never "waterproof").
  9. Fenner
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    Decided to remove the back again (thinking got it back twice so will get it back again) after all the help you have given I would like to obtain further info from you so enclosed the photo's of the movement and markings. Thanks for all your help.[​IMG][​IMG][​IMG][​IMG]
  10. gmorse
    7,303
    26
    Retired from Xerox
    Hi Fenner,
    The case is definitely 9 carat gold, and appears to have UK hallmarks for the London Assay Office, 1972, but no import marks, which I find a little surprising. I don't know who the sponsor's mark of "SD" belongs to. I don't think this is an ETA 1080, but if you can clarify whether there are any symbols or numbers stamped on the bottom plate next to the balance, it will help.
  11. roughbarked
    Dec 2, 2016
    1,945
    watchmaker
  12. Fenner
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    Thank you Graham. after looking closely on the bottom plate there is definitely no markings visible. Would there be, apart from gold value any value in the watch being a Rotary even with the dis-colouration of the dial.
  13. gmorse
    7,303
    26
    Retired from Xerox
    Hi Fenner,
    Forum rules preclude any discussion of value, but I think I'm safe in saying that you won't be retiring to the Bahamas with this one. These A. Schild movements were made in their millions and were used by numberless companies under all sorts of names.
  14. Fenner
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    Much appreciated Graham thanks for everything might weigh it in. Fenner
  15. roughbarked
    Dec 2, 2016
    1,945
    watchmaker
    Per gram for old gold at meltown price you did a bit better than $5.
    Not really worth the effort though. Rotary did buy the slightly better than lower standard movements produced by what was already then, Ebauches SA.
    In my mind it still deserves to be worn on a wrist.
    This wasn't the most common movement out there. The parts may be worth something to someone?
  16. Fenner
    Sep 25, 2012
    279
    Barnoldswick.Lancs
    Thank you Roughbarked finally you've changed my mind. I agree. Thanks once again for your support.
  17. Robert Gift
    Robert Gift Registered User
    Nov 12, 2012
    184
    Tree service "Branch Manager". Medical courier
    Denver, Colorado
    Are there parts that can fit other watches, or just this kind of watch?
    Does "Rotary" mean anything?
    Thank you.
    Robert
  18. roughbarked
    Dec 2, 2016
    1,945
    watchmaker
    OK Yes. Someone may want a ratchet wheel with the Rotary insignia. Otherwise any other watch movement in the same family should be able to use most or all of the parts.
Similar Threads - Rotary wrist watch Forum Date
Rotary Wrist Watch Wrist Watches Sep 26, 2014
Ellis rotary incabloc 17 jewel Wrist Watches Apr 23, 2012
Help identify vintage ladies Rotary Wrist Watches Oct 19, 2010
Rotary watch? Wrist Watches May 26, 2009
Strap for Rotary Ladies Wrist Watches Mar 19, 2009
