The attached document is my initial attempt to draw together a number of sources regarding the Roskells. It was initiated by a document produced by Allan here and draws heavily on research by Dave Green here
Allan's document is a synthesis of the entry in Burkes Landed Gentry (1849) and I have subsequently used a copy of the entry in the 1846 edition as the basis of the attached. The two editions contain identical information. To this I have added information by Dave Green and from my initial inspection of trade directories.
At the outset, I would like to stress that this is an attempt to understand the various members of the Roskell family, who they were, when they were active, where they worked, with whom they worked and in general terms what they produced.
The document is very much a first attempt, I have more sources to go through and I know that Dave is hoping to provide additional information from his earlier searches. I hope others will find it of interest an be able to contribute to its improvement. As further information is verified, I will update the document.
I have tried to adhere to the principle of focussing on prime sources and to this end, any information where I have not seen the original source, is in italics. This does not mean that it is less accurate, simply that its accuracy depends on the myself, the source, and a third person. Where possibly I will try and track down the prime source and then remove the italics. To this end if anyone has further or conflicting information, can you please post a clear reference to the source and, if possible, a copy.
As I mentioned, my prime source was Burkes 1846 edition and I have used this to define the family tree. The latest dates published there are in 1837. This means it does not cover the birth of some of Robert snr's later grandchildren. Their details is taken from Dave Green's posting, as is most of the information in italics, there is also a reference provided by Allan which is identified as such. I have made a start of adding information from trade directories which are referenced. A '?' indicates my uncertainty - mainly used where a reference to a family member is ambiguous.
I have included all members of the family that I have discovered and emboldened those who were involved in the trade.
All comments are welcome - new information accompanied by supporting evidence, particularly so.
Finally, my thanks to Allan and Dave for their help and support.
John
[pdf]431111[/pdf]
John
[pdf]431111[/pdf]
