Hi everyone, I've been a clock collector for many years and recently got interested in acquiring an early key wind fusee watch. I don't really have a lot of experience with watches, but I do have a lot of patience and I'm in no rush with this particular little project.
I found this one online for what I hope was a decent price, however, I'm not too sure exactly what I have. The only other search result I found for Rose & Son was a discussion here about Swiss fakes. I believe this watch likely falls in that same category. I wanted to ask your thoughts on the watch. I'm not too concerned if it's a London-made piece or not, and I'm already fairly convinced that it isn't.
See other thread here: https://mb.nawcc.org/threads/rose-son-verge-fusee-anyone-heard-of-this-maker.94579/
From what I can tell, it looks like the outer case is not original to the main watch since the hallmarks are different, and it's not quite an exact fit (but it's very close). I made a very lazy attempt to date the hallmarks and it looks like the outer case might be in the range of 1800-1810 based on the F. The hallmarks on the inner case are very worn, so I'm completely unsure. The name on the dial does match the engraved signature on the rear plate of the movement. I quite liked the fancy shaped pillars. I thought these were square, but they're actually pentagonal, which seems like a lot more effort to do.
The ruby setting on the back cock is rather interesting. It appears to have facets on the upper (outer) part of the jewel which seems strange to me as I'm used to seeing watch jewels as just simple doughnut rings or cabochon style end stones. I thought it might be a later addition, but the screw locations (when looking at the back) appear to have been incorporated into the design. As I'm new to watches I'm not sure if I should take the screws off and clean the stone or leave the entire assembly together.
As for repairs:
The hair spring is broken (but present), and having removed the balance, I'm a bit worried that replacing the spring might be quite a challenge for me. I'm not sure exactly how precise the replacement spring would need to be as far as length and number of coils. I've seen a number of these early watches with very sparse number of coils and rather coarse looking hairsprings. I'll likely ask more questions about this in a separate thread. I may have some loose ones in boxes of scrap parts from my grandfather's things (he worked on watches).
For the crystal, the watch needs one approximately 450mm and "high dome" style. I've seen some early fusee watches with and without a ground flat circle in the glass, and I'd really prefer one without the flat, however the replacement ones I can find online only seem to offer the type with the flat ground top. Does anyone know a source for a regular high dome crystal? It's too bad it doesn't use a standard crystal since I have about 150 spare ones in all sorts of sizes.
The missing hands should not be an issue as I can find or make some to suit. The potence bits are kind of an overly complicated mess of brackets and screws. I have not tackled that part yet. I can't really understand why there are so many pieces involved. The mainspring appears to be ok, but I see some rust from the barrel opening, so it may or may not be safe to use. I do also have hundreds of spares, but no idea of the size needed yet. The fusee chain appears to be in perfectly fine condition, but there is some light rust, and it's fairly dirty and a bit stiff. I'm fairly confident that it will clean up nicely.
There's a bunch of light surface rust here and there, but all the bits and pieces appear to be in fantastic shape (nothing broken, no ugly file marks or apparent repairs, no excessive scratches etc). The only repairs I see are that there were attempts to close the balance cock screw hole to tighten it, and some slight "hole closing" efforts made on some pivot holes (unless this is original).
As for repairs:
