I have spent the last few weeks reading and watching videos with the short term goal of being able to clean and oil (basic service) pocket watches. Eventually I would like to do some advanced repairs but understand that takes time, practice, and more tools. I just about have all the tools needed for basic service and have a couple of practice movements. Tonight I decided I was ready for my first disassembly. I'm proud to say nothing was damaged and as far as I know, no parts were lost. I took pictures along the way and laid all the parts out on a sheet of paper with notes. Once my cleaning solution and oils show up I'll be ready for the first attempt at assembly.
The first project movement is an Elgin 12s Gr 303 Mod 3. The balance would rotate for a few seconds and the second hand moved. It was definitely dirty upon takedown.
1) Is it a safe assumption all the parts are there?
It has a decent dial but I will need hands.
2) From all I read it appears any Elgin 12s hands are appropriate?
It did not come with a winding arbor and crown. I understand I could use a bench winding tool but I don't have one yet and I would like to make this completely functional when completed. The winding arbor is my biggest stumbling block right now. When I looked at Pocket watch database It says the Elgin part number for the stem is 1774. It also shows a total of 50 different grades using the same stem. I assume this makes it a very common part but after some time searching I can't find one under that number. It's clear I am lacking some knowledge in this area. I'm not concerned about originality only function.
3) Am I correct assuming winding arbor and winding stem are the same part just different terminology?
4) What terminology or type of number should I be looking for?
I understand many stems are long to allow for fitting to specific cases. I also believe crowns are kind of universal assuming you have the correct thread pitch. I have not looked into crown part numbers yet. If there is an easy way to clarify them I would appreciate it.
Thank you for any assistance.
