Rolex Datejust 3035 date shifting problem.
Discussion in 'Watch Repair' started by Skutt50, Jul 5, 2017.
  1. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    2,897
    Gothenburg
    I have a Rolex Datejust that just has been serviced. (Friend of mine. I don't have the tools myself.)
    The watch worked perfectly before, but after service the date shift is sometimes jumping 1,5 dates. This happens around the end and beginning of each month, e.g. from 28 to 29,5. I can quickset the dates and it works fine and after the 4:th or 5:th shift into the month it works normal until the end of the month.
    Any thoughts or ideas what can cause this behavior?
  2. Paul_S
    Paul_S Registered User
    Mar 27, 2015
    154
    The 3035 movement has a reputation for having a touchy date wheel with centering issues. The wheel's teeth need to be in perfect form for it to snap into position. From what you mention, it is possible that a tooth was chipped or bent during the service, but there are a couple possibilities. You would need to remove the dial to be sure.
  3. Skutt50
    Mar 14, 2008
    2,897
    Gothenburg
    Thanks.
    I was hoping it would be the the date wheel since it is something I should be able to inspect and possibly replace myself. I will have a look at it when I get back to my workshop.
Similar Threads - Rolex Datejust date Forum Date
Second Hand Not Moving in Rolex Datejust After Shipment Watch Repair Feb 8, 2016
Rolex Datejust Watch Repair Dec 8, 2015
Rolex Datejust suddenly lose time... Watch Repair Nov 4, 2011
need a genuine Rolex movement 2135 to fit a ladies Datejust Watch Repair Nov 15, 2003
