Rod chime
Emerson Pansarin
New Member
Feb 28, 2021
Dear all,
I need to restore a westminster Mauthe clock. Two rod chime are broken.
I need to know the material that these iron 3,2mm rods are made.
All the best,
Emerson Pansarin
wow
Jun 24, 2008
5,162
524
76
Pineville, La. (central La.)
Dear all,
All the best,
Emerson Pansarin
Welcome, Emerson. Probably the best solution is to replace all of the Westminster rods. Finding rods that match the ones you have is almost impossible. If you find rods, they will not be tuned to the proper pitch. You can order complete sets from suppliers such as Timesavers, Merritts, and others.
Reactions: disciple_dan
tracerjack
Jun 6, 2016
1,713
249
Lodi, CA
The old chime rods were not all made of the same metal. The only chime rods available today are made of either steel or copper. You can purchase single rods that are longer than what you need, but then you will then have to spend some considerable time tuning them to match the ones you have. It can be done, but having done it myself, it is a lot of work. Wow is right that it is much simpler to buy a tuned set.
disciple_dan
Mar 10, 2016
995
81
Plant City
Not to highjack this thread but I have a related situation. It's from a Seth Thomas Granddaughter clock. The rod that is broken is a 3.4mm x 17 11/16" steel rod. So, if I install the closest rod I can find which is 3.3 x 17 1/4 at Timesavers. It may or may not be tuned, correct?
So, would it be wise to get the 3.3mm x 18 and most likely have to shorten it to tune it, or is that the way it works at all?
I know it's better to get the whole set but I just want to try.
Thanks, Danny
14,049
1,494
It WILL NOT be tuned to your other rods. Yes, get the longer new rod. And, nobody knows exactly what length the new rod will need to be. And, if you cut the new rod to short, you get to start over, so be sure to order 2 or 3 new rods.
You can tune the other rods to make the correct chord with the new (to short) rod.
But, I would highly recommend that you work with the one (new) rod only and leave the others alone.
A professional piano tuner or musician can be a big help. An electronic tuner can also be a big help. Willie X
wow
Jun 24, 2008
5,162
524
76
Dan, two rods that are the exact same length and diameter may not be the same pitch musically because the alloy is different. Like Willie said, just buy two of the 18 inch rods and cut or grind one slightly shorter until it is the right pitch. Are you talking about Westminster or bim bam?
14,049
1,494
A musician or piano tuner can identify the missing note and carefully sneak up on it without overshooting it. An amateur doesn't know where they are going and will overshoot the mark nearly every time.
disciple_dan
Mar 10, 2016
995
81
Plant City
Hey, thanks for the help. Westminster. I'm definitely an amateur here Willie. So, I install the new rod. I have a guitar tuner on my phone. I can screw the block to my wooden bench to create somewhat of a sounding board. So, do the hammers start from back to front? This is an Urgos 406-001 which I'm sure must be a Seth Thomas number. Then can I grind and check and grind and check?
wow
Jun 24, 2008
5,162
524
76
Sometimes one of the rods on the strike side matches the pitch of the missing rod. Try that first. If so, you do not have to be as exact on the strike side. Any note that is not dissonant will work. Mounting the block on your bench is not the best idea. It is difficult to hear the overtones that way. Mounting in a box of some kind is better for hearing the tones and helps in tuning it perfectly.
disciple_dan
Mar 10, 2016
995
81
Plant City
Good idea. The rod that is missing is the one closest to the movement. What note will that be? Is it G#4 or B3 or another?
wow
Jun 24, 2008
5,162
524
76
They are not all tuned to the same key. You will need to listen to the ones left and figure out what note is missing. Have you checked the pitches of the remaining rods and found their names? If you know the other notes, I can tell you what the missing one is.
disciple_dan
Mar 10, 2016
995
81
Plant City
Yeah, the shortest rod is the farthest from the movement. I'll try to see if I can come up with the other notes with my guitar tuner on my phone.
Thanks for all the good help, Danny.
46,693
1,911
Your guitar tuner may not be of much help. They are designed to detect and tune to exact pitches for E,B,G,D,A,E. Your chime rods are not likely to be close to those pitches, so the tuner will show them as terribly flat or sharp - and not much more. If you have a good musical ear, the mind/ear combination will make the necessary adjustments for the key your chimes are tuned to, and adjust for flat or sharp as well. If you don't have a good ear, find one of your friends who does and persuade him to help you tune it.
14,049
1,494
As Bug's just mentioned, there is no 'note' that can be spoken of. You have to use a tuner with a sliding scale. Once it's registered, then you can go from there. It's all about 'intervals', in relation to a non standard "note", sometimes called an "in-betweener". Ha. Willie X
disciple_dan
Mar 10, 2016
995
81
Plant City
My tuner is called "Cleartune" It's an app on my phone. I don't know if it will work or not.
So really, would it be my best bet to mount the block and install the movement and then tune it by ear? It's one of those Seth Thomas granddaughter cases with the hood that slides off forward. It would be very difficult to tune with the block and movement installed. I brought only the movement to my shop.
Where can I mount it outside of the case and wrap on the rods to get a clear resounding note?
Thanks again, Danny
wow
Jun 24, 2008
5,162
524
76
Make a video of it as you tap on the three rods and I will tell you what pitch the missing rod should be. It may be on the strike side already.
disciple_dan
Mar 10, 2016
995
81
Plant City
Yeah, Will. I've been thinking about the strike side as you mentioned. If it has one tuned to what I need it only makes sense to swap them out and try tuning the new one on the strike side.
I have to go to work at my job for the next few days so I'll let you know when I get the rods and am ready to try.
Thanks, a bunch to all, Danny
Rod Schaffter
Mar 20, 2020
208
39
59
Often on Westminster clocks, the long rods on the strike and chime side are the same pitch.
Getting the note with an electronic tuner hasn't worked well for me as there seem to be a lot of overtones that interfere. The free gStrings app on an Android phone worked well for me for matching pitch. Screwing the chime block to a piece of plywood will increase the volume for testing.
Cheers,
Rod
disciple_dan
Mar 10, 2016
995
81
Plant City
Ok, I finally got the new chime rod and I'm attempting to get it tuned. It's 3" longer than the original one. Do I just keep nipping the end off until it sounds right? What about tone versus pitch? I'm not sure how to start.
I can make a video if needed. Thanks, Danny
wow
Jun 24, 2008
5,162
524
76
Dan, the length will probably not be the same as the original broken rod due to the composition of the metal in the new one being different. And, yes, you start gradually cutting or grinding the end off until you get it exact. Tiny cuts at a time are necessary because if you get it too short, you went too far. Get a tuner or a keyboard and use that to guide you.
A video of the new rod mounted in the block and tapped along with the others, would help distinguish how far off it is.
ChimeTime
May 4, 2021
54
13
70
NE Georgia
There IS another way.....
Download a Westminster ring tone onto your phone, and then
train the hammer to strike the key on your phone to make the phone ring.
:emoji_joy:
wow
Jun 24, 2008
5,162
524
76
Dan, the four chime notes are good. The hour gong should be fine too. I’ve heard many combinations of chords on the gong side. Should be great in the clock. Make us a video after you get it installed with the movement working.
disciple_dan
Mar 10, 2016
995
81
Plant City
Yes, Emerson was the OP. I didn't mean to take over your thread Emerson, I hope you got the help you needed from it.
I'll be installing the chime block and movement real soon. I'll be sure to make a vid. and share it.
Thanks for all the great help, Danny
166,139
1,447,305
86,684
ds23pallas
2,883
