American PW Rockford Watch Repair question
Discussion in 'Watch Repair' started by lopab23, Apr 13, 2017.
  1. lopab23
    lopab23 Registered User
    Oct 24, 2016
    Hello,
    I live in Byron, IL and was wondering if anyone knows of a reputable repairman/shop that I can send my watch to. The two issues with my watch. The first is that it runs very slow (loses around 5 minutes per day or so). The second issue is that I just broke the crystal. The bezel and case are fine, but it just tapped the crystal hard enough to break it (the watch was running slow since way before I broke the crystal). This is a 16S watch. Thanks in advance for any advice you guys may have. :)
    Pablo
    [​IMG][​IMG]
    Attached Files: Download all post attachments
  2. 18k BPH
    18k BPH Registered User
    Aug 18, 2016
    26
    While I can't recommend a repair person, perhaps I can provide information you can give to a repair person when you find one.
    Based on the serial number, your watch appears to be the following:
    [​IMG]
    Also, according to the "Swigart Illustrated Manual of American Watch Movements" catalog, it uses a Rockford 451 spring:
    [​IMG]
    Allow mainsprings can be found here: http://www.ebay.com/sch/i.html?_odk...ng.TRS0&_nkw=rockford+451+mainspring&_sacat=0
    I hope this helps!
  3. Samantha
    Samantha Registered User
    Jun 28, 2009
    887
    Female
  4. darrahg
    darrahg Registered User
    Dec 22, 2006
    1,172
    Your watch looks like it is pretty good shape and probably just needs a good cleaning, main spring (the old one is probably set) and, of course, the crystal. Try and find a watchmaker that works, or preferably specializes, in pocket watches similar to yours. The watchmaker should also be able to clean up the dial so that the hairlines are less noticeable. Good Luck.
Similar Threads - Rockford Watch Repair Forum Date
Assistance on sourcing upper balance jewel for Rockford pocket watch Watch Repair Jan 9, 2017
American PW Rockford Balance staff for size 18 Watch Repair Dec 15, 2016
rockford sz12 single roller balance staff and wm mckinly sz 16 Watch Repair Aug 22, 2016
Rockford Balance staff. Watch Repair May 19, 2016
American PW Rockford pocket watch parts ID Watch Repair Jan 4, 2012
