• Upcoming updates
Rockford serial number query
Dave Coatsworth
Senior Administrator
NAWCC Business
Feb 11, 2005
9,264
4,274
Camarillo, CA
www.daveswatchparts.com
Can someone out there with a Rockford serial number list tell me if #896669 is a Grade 930? (Or, if it isn't, what grade is it?) Thanks!
John F
Sep 28, 2001
Dave - can you post a pic of your Rockford? The company's published SN lists stopped at 824,000, meaning that listings higher than that are "reconstructed" and based on observations.
(Also, trying to figure Rockford grades is sure fire way to get a quick ticket to the funny farm. :biggrin: )
Dave Coatsworth
NAWCC Business
Feb 11, 2005
9,264
4,274
Camarillo, CA
Hi John,
It's eBay item #320041975225. (Unfortunately the photos are not that good...) It's actually not mine. I'm just trying to help this charity with a couple of pocket watch listings but my knowledge of Rockfords is VERY limited.
John F
Sep 28, 2001
Grades 930 and 935 are virtually identical in appearance and I personally don't know of a way to easily distinguish one from another based on viewing the movement (e.g., adjustment markings, etc.).
A 1906 catalog description of each is almost exactly the same, except the 930 is described as "adjusted to heat and cold" and the dial has "red marginal figures," while the 935 is not listed as adjusted and the dial has only "marginal figures" (not red ones). If the dial on the one on ebay is original, then the red minutes would suggest that it's grade 930. But without more I would hesitate to make that conclusion.
Dan - what's your source for this as a grade 935?
Kent
Gibbs Literary Award
NAWCC Star Fellow
NAWCC Gold Member
Aug 26, 2000
18,753
2,704
I thought that the No. 930 was marked "Adjusted" while the No. 935 was not.
Greg Frauenhoff
Aug 25, 2000
5,324
3,847
Dave,
A Jan. 1913 price list describes the grade 930 as "Adjusted to Temperature, Sunk Second Dial". As such, I would expect there to be an adjustment marking of some kind on the plates if it is a 930.
John F
Sep 28, 2001
Greg - how confident are you that Rockford was conbsistent in its movement markings in its final years in operation? That's where I'm hesitating on concluding the grade for this watch. (I agree that it's more likely a 935 than a 930 in the absence of a marking, but I'm just reluctant to be firm on that.)
Greg Frauenhoff
Aug 25, 2000
5,324
3,847
John,
Anything's possible, but as I see it, if #896669 is not marked "Adjusted", there are 2 reasonable possibilites:
It's a 935
It's a 930 "error" (somebody forgot the adjustment marking...it happens)
The former one is by far the most likely (in my opinion).
180,087
1,571,001
54,369
wbaNev
911
3,097
Philadelphia Watch Case Co. by Kent
