Riffler file recommendation
Rockin Ronnie
Nov 18, 2012
1,605
125
Greenfield, Nova Scotia
antiquevintageclock.com
Can anyone recommend a set of riffler files for brass work? I had some trouble filing down a protruding bushing this week and could have used one. I see lots on Amazon for wood carvings. Best to get what? Fine, medium?
Ron
tom427cid
Mar 23, 2009
1,663
100
Moultonborough,NH
I have seen a file that is called a bull's foot or something like that which would probably suit your needs.
Hope this helps.
tom
Kevin W.
22,691
407
I have seen riffler files for wood, but not for metal. I commented to you Ron in my FB group.
Jim DuBois
Gibbs Literary Award
Jun 14, 2008
3,073
709
Magnolia, TX
I made these using file cut-offs recessed in aluminum blocks. I milled the slots a bit deeper than the thickness of the files, then bedded them in epoxy on a very thin shim which keeps the file recesses about .0005". That allows the leveling of bushes and other parts very close to the plates. I didn't find any better way and bulls foot files, if you can find them, will mar plates unless absolute care is used. This method works well and is close to foolproof.
Similar threads
Topic related ad experiment
160,865
1,395,693
82,875
jr webster
1,099
2,787
