"Rhythm" quartz mechanical bim-bam (from Bulova clock)
Discussion in 'Electric Horology' started by kinsler33, Sep 8, 2019.
  1. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    3,172
    338
    Science teacher, writer
    Lancaster, Ohio, USA
    This particular sweetie is a continuous-motion quartz movement with a mechanical bim-bam strike. I'd replace the whole thing but they're around $100, so I'm trying for a repair. There are two controls: a pull-to-set stem that seems to do nothing in it's un-pulled position, and a mechanical stem that locks the two hammers together to provide a non-bim-bam strike rather than a bim-bam. And that's it. One D cell powers the whole mess.
    The problem is that the strike doesn't always strike. I haven't found a pattern. It's vigorous enough when it does strike, and the pair of contacts that starts the strike work well, except when they don't. For there is a clear plastic finger controlled by a cam on an intermediate wheel of the time movement that blocks the contacts so they won't close on the hour or half hour.
    When the strike does work, it's interesting because this clock uses a regular rack and snail to count the strikes.
    These can be seen through the window at the front of the clock.
    I suspect that this thing has some magic features that aren't quite working or too obscure for me to understand. Any ideas?
    Mark Kinsler
