Restoring unusual Tall Clock
Discussion in 'Clock Case Restoration and Repair' started by tom427cid, Feb 1, 2019.
  1. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,589
    73
    Cabinetmaker,clock repair
    Moultonborough,NH
    This case came to me to be restored/reglued !!. It was in pretty sad shape. It had been reglued a couple of times before but the old glue was never cleaned off. (Ya can't glue glue!) During inspection of the case it was noted that originally the case was built in three sections. First I've seen or heard of. Second, the builder was trained in the English Style. That is to say major pieces such as waist sides,bonnet sides,base sides,and the like are very thin 3/8" or so. These pieces are thinner still,a bit over 1/16". The back and secondary wood interestingly is American Pine. And the movement is also American. One of the challenges I faced was that the joint between the waist and the base was never quite finished. The only attaching point was between the back of the waist and the back of the base. It would be nice to keep this feature if the two pieces could be securely attached to each other. More importantly it had to be consistant with the style of the original maker. It also meant removing glue blocks that were a later addition(in an attempt to stabilize the joining of the two pieces).
    Here are some pics of some of the high lights of the restoration. Also I had to replicate missing banding on the base. To give one the idea of the size of things the black and white pieces are .050 x .100" and the finished width of eight layers is .420" about 7/16".
    DSCF0946.JPG DSCF0954.JPG DSCF0959.JPG DSCF0965.JPG DSCF0967.JPG DSCF0982.JPG DSCF0984.JPG DSCF0987.JPG DSCF0992.JPG
    Dave T, Jim DuBois and BogWood like this.
  2. gleber
    gleber Registered User
    Jun 15, 2015
    1,625
    169
    Underwater Robotics Expert
    Downingtown, Pennsylvania USA
    Nice restoration Tom!
    Tom
  3. Sooth
    Sooth Registered User
    Feb 19, 2005
    3,899
    Cabinetmaker
    Cornwall, Ontario, Canada
    Nice job as usual!
  4. klokwiz
    klokwiz Registered User
    Feb 4, 2009
    1,271
    36
    WRENCH
    Annapolis, MD
    Tom, very nicely done. Would you mind telling how many man hours this took? Joe.
  5. klokwiz
    Feb 4, 2009
    1,271
    36
    WRENCH
    Annapolis, MD
    Tom,
    In re-reading your post I was wondering do you mean that the three sections were made to be easily separated say for moving? or were they just built separately and then permanently joined to each other? Joe.
