Restoring the 400-Day Kaiser Grand Universe
Discussion in '400-Day & Atmos' started by Moeby, Sep 16, 2019.
  1. Moeby
    Moeby New Member
    Sep 16, 2019
    Hello,
    I am new to restoring clocks. I have just cleaned up my Kaiser clock. The suspension spring is broken. Where can i get the torsion wire replaced? is this the correct part? Kaiser
    Measurements -
    113m x 9mm Standard 54 (34)
    I have a few problems in restoring the clock.
    1. Replace the torsion wire. Entirely missing.
    2. The screw that holds the 1 of the 4 weights is broken.
    3. I dont know how to balance the weights and set the timing.
    Please help.
    Thank you.
    20190623_162921.jpg 20190821_143148.jpg 20190813_164921.jpg 20190821_143708.jpg
    markiemark likes this.
  2. KurtinSA
    KurtinSA Registered User
    Nov 24, 2014
    3,233
    100
    Aerospace Engineer (Ret.)
    San Antonio, TX
    Welcome to the message board! Can you show a picture of the back plate without the suspension guard? That will help narrow the specifics down for the clock.
    Kurt
  3. Moeby
    Moeby New Member
    Sep 16, 2019
  4. KurtinSA
    Nov 24, 2014
    3,233
    100
    San Antonio, TX
    The plate appears to essentially be #1309A in the repair guide. The thickness of the replacement suspension spring is 0.003". I'm not familiar with the diagram shown for the suspension spring assembly. The Terwilliger repair guide does indicate it is unit 34 but the location of the fork is much different than your generic picture. In the US, I tend to buy my replacement springs from The Horolovar Store and then cut the spring to the proper length. Of course, top and bottom blocks are needed...they can likely also supply those blocks. If you're comfortable doing it, it's relatively easy to assembly the suspension unit to the proper dimensions.
    Kurt
  5. Moeby
    Moeby New Member
    Sep 16, 2019
    The bottom block is missing. I would probably need the whole set. Could you kindly click on the kaiser link if that is the correct part.
  6. KurtinSA
    Nov 24, 2014
    3,233
    100
    San Antonio, TX
    I did go that link but I really don't know what I'm looking at. I guess from the descriptions 113mm is the length and 9mm is the distance to where the fork tines are. Seems right when compared to the #34 suspension unit in the repair guide. Be sure that you will be getting a true Horolovar spring as other springs may not have the temperature characteristics and thus your time regulation will be difficult.
    Kurt
  7. markiemark
    markiemark Registered User
    Nov 21, 2017
    74
    Select #34 from this link 400 Day Clock Suspension Unit
    Although I do have a Kaiser Grand Universe I used #34 for my other Kaiser Universes.
    I do use Cousins UK for other stuff, it's a good shop, but for the Kaiser I have used both and the Horolovar just seemed to fit better.
    I could probably answer all your other questions too, but I'd need to dismantle my clock. Do your pictures show all your pendulum parts, I see some missing, like do you have the shaft that goes through the globe?
    Mark
  8. markiemark
    Nov 21, 2017
    74
    These parts... I found some old pictures. I know you have the weights but the black piece and the nut, and the curved insets on the other pic.
