Restoring matting on brass dial clocks
NigelW
Jan 2, 2015
452
44
London and Kent
Is it possible to restore the matting on old brass dial clock? The dial on one of mine has had some later holes plugged but the restorer left some scratch marks in the matting and one small area of matting is slightly flattened. The scratching is very light and only visible when the light falls on it from certain angles and probably won't be noticeable when it is in the case, but the flattened area is noticeable. I suspect that the scratching will become less visible as the brass tarnishes a little as fresh scratch marks tend to be more noticeable than old ones.
novicetimekeeper
Jul 26, 2015
10,927
873
Dorset
It was done with a spiked roller, not always but that is the most common method. Some early provincial clocks seem to have been done with a single point!
I have seen reasonable attempts at matching up a new rivet end in a dial. Some london matting is incredibly fine, so it would be hard to match that I think.
Reactions: NigelW
NigelW
Jan 2, 2015
452
44
London and Kent
Looking closely at mine it seems it was done with a square punch. The slightly flattened area is next to the the hour hand, and hidden by it in the "before" photo. I suppose one could try making a similar punch?
novicetimekeeper
Jul 26, 2015
10,927
873
Dorset
If you look behind the chapter ring you can usually see how it was done. There should be enough there for you to trial any proposed solution too.
Reactions: NigelW
165,343
1,439,095
86,157
deendapunks
2,873
