Restoring Columns on Ansonia Iron Case Mantle Clock
Discussion in 'Clock Repair' started by derwiener, Dec 25, 2016.
  1. derwiener
    derwiener Registered User
    Old Timer NAWCC Member
    Aug 8, 2009
    50
    Below are pictures of the columns from an Ansonia clock that I would like to restore. I'm not sure what the metal is, but the main columns seems to be of different material than the tops/bottoms. The bottom column part on the left is shiny yellow, and I assume the rest should be the same. I have tried cleaning with Brasso, etc, but I think the finish, whatever it is, has worn away. If there is no way to restore them without getting them refinished, I'd like to paint them a gold color. I's appreciate any suggestions about what paint is suitable for this purpose.
    Thank you, and Merry Christmas!
    Paul
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    3,737
    275
    watchmaker
    I had to use quote reply to see your images. Not sure why.
    To restore these as they were, you'd need to gild them I believe. Some were still available to buy and presumably some still may be.
    If you do decide to paint them or get them regilded, they will still need to be meticulously cleaned first.
  3. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,127
    397
    Probably not a good idea to use Brasso or any kind of polish/abrasive on these types of ornaments. A lot of them are spelter with a thin finish. I agree with roughbarked, application of gilt would look best. The problem with metallic paint is that it tends to obscure detail and it is not as stable over time as gilt will be. It doesn't have to be true gold, but gold "colored" leaf or gilt will need to be sealed. Good luck with it.
  4. BLKBEARD
    BLKBEARD Registered User
    Nov 15, 2016
    759
    24
    HVAC, MECHANIC, CLOCK REPAIRER
    CT
    They were likely Fire Gilded, a process no longer available due to the involvement of Mercury in the process.
    Gold Leaf Gilding is easy enough to accomplish without any high tech skill set. That will leave you a bright Gold Finish. Should you desire, a antiquing glaze is available to tone down the brightness. You could also send the components out to be brass plated, or paint them. I've done Gold Leaf Gilding, and I barely have an artistic bone in my body.
    You might google "restoring fire gilded objects" or similar searches to see what pops up
  5. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    53
    Calgary, Alberta
    Or have someone anodize them gold. As in, gold electroplate.
  6. Willie X
    Willie X Registered User
    12,461
    852
    Rub-n-buff makes em look good to me. Originally they had various finishes from paint to guilding. I am in the camp where an old clock should look like an old clock. This is a practical choice to me, mainly because when you make one single part of an old clock look like new, that part sticks out like a sore thumb, looks terible. So once you start down this 'slippery slope' there is no good place to stop ... Even if a clock is a total wreck you still have to take a measured and well planned approach to come up with something nice.
    In short, I would try to make all look like the left one if possible.
  7. Bruce Alexander
    Feb 22, 2010
    6,127
    397
    #7 Bruce Alexander, Dec 25, 2016
    Another option would be Sculpt Nouveau products. You can replicate patinas but the "restoration" may differ as the parts with original finish continue to age. The final overall finish of the clock needs to be stabilized and preserved. Periodic application of wax finishes is one way to accomplish this. See: https://www.sculptnouveau.com/ to get some idea what is possible. I have used these products alone and over gilt finishes and I think I've attained some good results. I've heard some good things about rub-n-buff but I have never tried it myself. This is another area where art overlaps with Horology. Have fun.
  8. Fitzclan
    Fitzclan Registered User
    Jul 20, 2014
    580
    Long Island, New York
    #8 Fitzclan, Dec 26, 2016
    As you can see, there are several ways to approach this kind of restoration. If you use rub n buff, I suggest that you use it sparingly leaving the recesses dark. This gives you a more natural Antique look.
    Fake gold leaf is also easy. I use a spray adhesive, then leaf. This gives a very brash gold. color which can then be toned down with an oil based wood stain. Paint the stain on with a small brush and then wipe it off with a rag leaving the recesses darker..
    After it dries a spray of semi gloss polyurethane will keep the finish from rubbing away..
