Restoring a 329 21j The Studebaker...
pmwas
Dec 12, 2010
2,198
1,452
Sosnowiec, Poland
No good watch. A wreck, nothing more. No dial, broken balance... replaced regulator - BAD. But a 329 The Studebaker... so... I’m screwed, I have to make it run... damn it...
I bought a staff. The pivots were too thick, so I decided to do it the simple way - I replaced the - cracked anyway - balance jewels as well.
The dial I took from a 15j mid grade. I hope to replace it one day...
Ok, let’s go...
I began with the setting mechanism
All steelwork is mirror polished, but has some corrosion and fingerprints...
On with it...
Very simple, lever set mechanism...
Other side...
The escapement is all polished steel.
The pallet fork is bent down and does not engage the balance correctly...
Part of an old staff repair...
I tried to straighten the fork and...
...it was reluctant.
That would pretty much end the restoration here, but I still had the 15j South Bend fork somewhere...
No good... single roller
But what choice did I have:???:
At the point, I decided to scrap the 329 for parts, but...
Yes. Let’s make that double :D
Just a cut, the arbor, transfer the sapphire pallets and...
The fork is back again!
As for the balance, I broke the sapphire roller (I do break things when I’m angry)...
...and I had to use a brass one...
The balance has an overcoil (rusty) hairspring...
...and some filed down screws.
Not unexpected - rusty hairsprings tend to be slow...
Assembling...
2491AEE8-4293-4D9B-AE14-209332C26824.jpeg DF3B9E50-64B5-499C-987C-6941C095B96D.jpeg
Barrel:
E80AB70D-B93E-4645-ADF9-AEEECB92DE51.jpeg 065E3DC2-DF18-4A1F-BF5B-D15E6FA7185D.jpeg
And almost done...
And the original gold plated case:
Runs nice.
The dial is crappy...
So I still need a HQ dial, hour hand and crystal.
All in all... a working 329...
Not THAT bad :)
darrahg
Dec 22, 2006
1,535
622
Houston
It is not what I would call 'restoration' but you did get it running. Congratulations.
The moderator of this blog will be moving this thread to the 'Watch Repair' section.
pmwas
Dec 12, 2010
2,198
1,452
Sosnowiec, Poland
Yes... to finish the ‚restoration’ I still need the dial and regulator...
George Frick
Sep 8, 2016
231
70
I am amazed with your skills. One of my favorite watches. Thank you for saving this one!
pmwas
Dec 12, 2010
2,198
1,452
Sosnowiec, Poland
And dial from Dave’s stock.
It’s a replacement, painted metal dial, but double pressed, so to say RR grade style.
The result is.... beautiful!
164,769
1,433,559
85,789
ynolems
2,863
