I have posted this clock in the New Acquisitions forum and now have a question about restoration of the gilt finish. I have begun removing the gold overpaint and have found that the clock appears to have been gold leafed only in certain areas. The egg-and-dart molding and the narrow concave molding were definitely leafed over red clay. However, the wide band between these two does not seem to have been leafed. Under the later paint in this area, the finish is matte and appears also to be paint. Under the paint is a yellow clay or primer. It does not appear possible to remove only the top layer of paint, which is very thin, without affecting the bottom (original layer), which is also very thin. I may be left with the need to repaint the matte portions. The original gold leafed portions seem to be in good enough condition to retain as is, once the overpaint is removed.
Does anyone have a suggestion for a pre-mixed or custom mixed gold paint that will have a matte finish and a thin, smooth consistency? I have various bronze powders, but I'm not sure what to mix them with to achieve this finish.
There is also "shell gold," which is real gold powder mixed with gum arabic and formed into a tablet like watercolor paints. (It is available from www.talasonline.com.) It's expensive and I don't know that it would have been used for large areas like this, so I'm assuming the original finish on these matte areas was bronze paint.
Any thoughts or suggestions?
