Betzel
- Dec 1, 2010
- 1,071
- 268
- 83
- Country
- Region
Greetings,
I recently got an old set (6 pieces, double-ended, brass handled with steel disks) for a reasonable price (so I thought!) on eBay thinking they would be good enough to use, but they're not cutting very easily.
Not getting much from a fingernail scrape, so I thought I would try re-sharpening them. But, before I do, I thought I would see if anyone else had tried this / how it worked out. The thing that is difficult for me is keeping/holding them straight so the disk edge stays flat at 90 degrees, like an ice skate. And, they are just pinned, so the spindles that hold them in the brass are not great.
Anyone have a success story to share?
So far, I'm thinking maybe of wedging them (with some pegwood) into a T slot on the cross slide, oiling the pivots, then bringing them up to a cast iron lap from the screwhead polisher, held in a 3-jaw turning slow with some diamond paste on the wheel. Maybe placement like a car's front wheel on the road with too much toe-in lets it turn a little, but skid across the surface so it cuts at a slight side angle. All theory, and no practice though. Must be a better way...
TIA if you can help!
