Replacing tablet putty-Peter Nunes
Discussion in 'Wood Movement Clocks' started by dlb1052, May 26, 2019.
  1. dlb1052
    dlb1052 Registered User
    Feb 8, 2014
    7
    I believe I read some while back about using plaster of paris to replace the old putty. However, I cannot find the thread. I believe Peter Nunes made that suggestion. I think he mentioned using acrylic paint to dye the plaster of paris. My question is how and what proportion of paint to plaster of paris to water do I use (approximate is good) ? How long will it take to harden with this approach ? I think it sounds like a great idea, and want to try. Thanks.
  2. Joseph Bautsch
    Dec 9, 2006
    1,113
    123
    Atlanta, GA
    Plaster of paris by it's self is not a very good choice for replacing glazing putty. It just will not hold up. The old glazing putty was a combination of plaster of paris and boiled linseed oil. The drawback to using it is it takes a couple of weeks to dry. You can use modern water based glazing putty and food dye to color it. If you use oil based glazing putty you can get different color dye concentrates used to color stains to get the color you want.
  3. dlb1052
    Feb 8, 2014
    7
    Dear Joseph,
    It has been a while since my post question but better late then never. Thank you so much for your response and the information. I tried the putty and dry pigment method as one you suggested. It works great, easy to use, shapes nicely and the color I was looking for. Very much appreciated. Diane
