Four questions:
1) what is the age of this Pennwood?
2) there is an undamaged section of the power cord left and the place where it enters the coil might be intact, I haven’t opened it. I was advised the wires that the cord attach within the coil might be very thin and brittle so repair has to be done carefully. How can I tell if the coil is damaged beyond repair?
3) where can I locate another motor or wire 'bobbin' or find a complete mechanism to simply replace the original one?
4) to find a completely replace mechanism, what do I need? I understand this movement is used in many clocks that go by the name(s) of Pennwood, Numechron and Tymeter. They come in 12 and 24 hour versions so I need to be very careful if buying an entire mechinism.
