• Upcoming updates
Repairing main wheels
POWERSTROKE
Jan 11, 2011
1,884
213
Are there any videos of how to repair Maine wheels on cuckoo clocks?
49,521
2,941
What kind of repair? You can buy new main wheels ;)
POWERSTROKE
Jan 11, 2011
1,884
213
For a Hubert Herr for example. No longer in production. Anyone can buy a new one. I want to know how to fix it. Does anyone have a video?
49,521
2,941
We need pics, powerstroke. There were at least two different types of clicks. If the spring wire is broken, you'd likely have to remove the click, remove the old wire and replace it by staking it in.
Reactions: NEW65
Vernon
Dec 9, 2006
1,369
249
57
No video but I took one of mine apart so that you can see. The first picture shows the wheel supported by the crows foot. Note the brass collar on the arbor, not shown is a hollow punch on to the shoulder of the pivot. I tap the punch a few times to loosen the collar. I finish removing the collar with my pry bars. It looks like the ratchet wheel is riveted on.
Vernon
PXL_20221203_195405674.jpg PXL_20221203_195505511.jpg PXL_20221203_195536095.jpg
Reactions: NEW65
RJSoftware
Apr 15, 2005
8,851
279
Loxahatchee, Florida
The trick on a click is to add a shoulder on your rivot. Then peen as tight as you wants to.
On your click, wire is not supposed to be in that hole. Should be a groove on backside of click. the spring should have flat blade to fit in groove. The two wheel holes are used to tie spring steady to wheel.
Reactions: NEW65
18,023
3,492
I've seen that little click wire wear it's way completely through the brass click.
It's not much trouble to make a new click or click spring.
Vernon
Dec 9, 2006
1,369
249
57
I took the other chainwheel out as I was curious if the click wire was set up the same and it was. There are no grooves or other likely place for the click wire to locate.
I hope that this Herr matches what you have Power.
Vernon
Reactions: POWERSTROKE
POWERSTROKE
Jan 11, 2011
1,884
213
Thanks Vernon and the rest of you folks. Where do you get the new click wire? Does this come pre-formed? I'm assuming timesavers.
wow
Jun 24, 2008
6,981
1,241
77
Pineville, La. (central La.)
Who sells the tension spring (retainer) washers for these? When removing the retainer to replace the click spring, I broke it in two pieces.
0FC582BD-673D-4332-B113-252F9BB0A1A6.jpeg 5474C89F-0992-4D7C-A814-14724CF629E4.jpeg 3F26BC38-DBBE-4173-831F-0E9E20726A19.jpeg
49,521
2,941
Take a pic to your local hardware. They can probably fix you up ;)
wow
Jun 24, 2008
6,981
1,241
77
I use a thin gauge tie wire. Less pro, more practical.
Yes, R.J., I have done that too but this one has no groove cut in the arbor. The retainer has to be made out of hard steel and the tips dig into the smooth arbor and retain the tension spring. Maybe I could cut a groove in the arbor or drill it and insert a pin. You can’t remove these without breaking them.
RJSoftware
Apr 15, 2005
8,851
279
No groove,... man... Well, if hunting for correct fails, cut a groove. Then I might choose a cupped spring washer and a C clip for the groove.
But I hate going down improvise rabbit hole. Unseen design snags
Reactions: wow
Ken X
May 10, 2021
21
58
If its any help, searching for Starlock Washers brings up a fair selection.
Reactions: wow
18,023
3,492
Drill the arbor (1/16" is good) and use an 'S' wire (16 gauge), along with a washer if necessary. Most older German GF movements used this method. Willie X
Reactions: wow
49,521
2,941
Go to your hardware store! ;)
179,022
1,570,256
54,047
aztrukin
909
3,088
Swiss Fake by Kent
