This is my first Brillie; I have wanted one ever since I saw a photo, and this one had two advantages for me: it was a good price, and it was located in the U.S. I've had limited experience with electromagnetic clocks, owning an American Clock Company tabletop model, several SWCC models, a Bulle Type A and F and a SETCO master, and was daunted when first faced with the Brillie (I restore torsion clocks as a main hobby). Repeated reading of the AHS Brillie book, digestion of every post on the board about these clocks and various YouTube videos helped me gain an understanding of the functions of each part of the clock and gave me the confidence to start dismantling the various components. In the process I came up with questions related to the age of the clock:
- In all the photos in the book and online, it appears that the contact controlled by the star wheel has an extension on it to make with the two contacts facing it. On my clock, it is a U-shaped piece with a silver pin transversing it that makes contact. Was that an early feature that was replaced by the extension? As found, they were adjusted too closely, so that the circuit was always closed; I was able to get them adjusted correctly, although until I have a working coil, I don't know if further adjustment will be needed for them or the pawl.
- Did Brillie serially number their movements? The number 32 is stamped on the back of the movement, and the movement mount was stamped with another number (which I neglected to photograph before I reassembled and mounted the clock on the wall).
