• Upcoming updates
Removing the "Green Cancer"
f.webster
Dec 18, 2009
1,015
109
Louisville, KY
I have heard it referred to the "Green Cancer". My question is simple: How is it cured?
I am cleaning the bridges of a project pocket watch and wonder the best way to remove it . Do I polish it off, or scrap it, re-guild it, or just leave it be and never open the watch to show off the movement?
Remember I am a beginner with watches and DO appreciate everyone's wise counsel. How do you do it? How should I bring beauty back to these bridges?
DeweyC
Feb 5, 2007
2,884
1,552
Baltimore
www.historictimekeepers.com
I just try to stabilize it. Use heptane or IPA on a piece of pegwood and rub off as much as you can. Then into the cleaner. Repeat if needed or until bored.
Anything else depends on the extent of plate finish lost and the importance of keeping as much intact as possible. Most times the piece will not bear the burden of the cost of proper guilding. But owners are strange creatures.
Jerry Kieffer
May 31, 2005
3,184
791
wisconsin
Typically, If it can not be wiped clean, movement cleaning chemicals will not remove enough of the corrosion to prevent reoccurrence in a short time. In fact, it is unlikely even harsh chemicals will remove all traces required to correct the problem.
In cases such as this, my personal goal is to remove all traces of corrosion and restore original appearance.
If you closely inspect a Gilt movement finish, you will often notice that the finish appears to have a very fine bead blast type texture. Thats because thats what it is often used in the manufacturing process to economically blend manufacturing marks into a consistent even finish and appearance. To duplicate this finish, I use a Paasche Airbrush air Eraser attached photo with 320 grit glass bead. This removes all traces of corrosion while restoring original surface texture. I normally use about 20-30 PSI but that is adjusted to match original texture. In addition, after bead work, a small fine brass bristle brush is used to blend invisible where required. Once complete, normal cleaning fluids will blend Gilt color.
Jerry Kieffer
Reactions: viclip
f.webster
Dec 18, 2009
1,015
109
Louisville, KY
If this green cancer is a corrosion of the gilt, can it be treated like rust? I have chemicals that treat/remove rust from steel. I have used them on aluminum and cast iron. I wonder is a small amount on a q-tip might help remove the green cancer. Then maybe a light polish?
Opinions and suggestions...?
gmorse
15,054
4,173
Hi f.webster,
Gold is pretty unreactive and resistant to corrosion, that's why it's valuable. The green colour is, as Chris suggests, a corrosion product of the copper in the brass underneath.
DeweyC
Feb 5, 2007
2,884
1,552
Baltimore
I forgot to mention my "goto" on chronometer plates and gilt watches. It removes finger stains from chronometer plates (although if etched the prints will still be present) and makes fire gilding look new.
It is simple soap (AKA Ivory or other true soap), hot water and a brass brush that is as soft as camel hair. I bought 20 of these from Timesavers some time ago out of watchmaker paranoia. I do not know if they are still carried.
SImply lather up the brush like shaving lather and then scrub the plates. The brown stains will come out as will verdigis. The damage will still be there but it is not so apparent and the plates are bright with no damage to spotting or gilding.
Rinse in hot water and then I put them through the cleaning machine but you may choose not to.
I just did a chronometer yesterday. Next time I will take before and after pics. But the secret is the brush. It has GOT to be soft brass.
Reactions: Randy Beamer
f.webster
Dec 18, 2009
1,015
109
Louisville, KY
So here is what the beginner did. I took the advice I got here and...
First I put it through the cleaner then I took a pith-stick and with some naphtha I rubbed of as much as I could. Next I took some vinegar and after a short soak I address it again with the pith-stick. Another trip through the cleaner. Then with a soft cloth and some Novus 2 polish, I gave it a pass before final trip through the cleaner. There is still one spot...I'm not calling it cancer... a booger in the serial number. It looks much better.
I am thankful for those who shared with me.
DeweyC
Feb 5, 2007
2,884
1,552
Baltimore
Actually, came out much nicer than I would have expected. Congratulations!
Dave Haynes
Sep 12, 2000
1,524
107
I use a baking soda / water solution. it removes verdigris chemically.
180,056
1,570,752
54,364
clockminded
911
3,090
