Removing paint specks from my clock case
Discussion in 'Clock Case Restoration and Repair' started by tliette, Aug 9, 2017.
  1. tliette
    tliette Registered User
    Feb 13, 2014
    12
    I have a clock case with specks of white paint on it's case (a Seth Thomas Beehive), I don't want to ruin the time aged finish that has taken so many years to create. I think that is one of the things that makes collecting antique clocks unique. Is there a way that I'm not aware of this visual eye sore can be removed in a safe manner? I would include photos but the clock is in the clock shop. Thanks!
    Ted
  2. novicetimekeeper
    Jul 26, 2015
    4,821
    Dorset
    if you are lucky you can usually ping them off with a fingernail.
  3. BLKBEARD
    BLKBEARD Registered User
    Nov 15, 2016
    619
    HVAC, MECHANIC
    CT
    A Dental Pick works very well. One speck at a time.
  4. tliette
    Feb 13, 2014
    12
    Hummm, but what are the dangers of marring the finish?
    Ted
  5. harold bain
    Donor NAWCC Member
    39,961
    I have good luck with a pocket knife, a steady hand and lots of patience.
  6. BLKBEARD
    Nov 15, 2016
    619
    HVAC, MECHANIC
    CT
    The speckles are usually just on the surface. Dental picks are small enough to target the speck & not the surrounding area. I buy good professional quality used ones from ebay. They're very sharp & strong.
  7. tliette
    Feb 13, 2014
    12
    Thanks Blkbeard!
    Ted
  8. Time After Time
    Feb 22, 2010
    3,118
    13
    Retired General Dentist
    Something else that has worked well for me from time to time is a simple popsicle stick. They can "push" paint specs off of a shellac surface pretty easily without damaging the shellac or wood finish.
  9. George Nelson
    George Nelson Registered User
    Oct 5, 2007
    884
    Tennessee
    The popsicle stick method has always worked well for me as well. The advantage of simple paint specks is that they originally landed lightly on the surface, and were not worked into the wood with a brush. Many times, there is either furniture polish or some type of furniture wax on the surface of the clock to prevent the paint from truly absorbing into the surface with any great adhesion. You can get clean wooden popsicle-type sticks at any crafts store.
    Best to all,
    George
Similar Threads - Removing paint specks Forum Date
Removing alkyd paint Clock Case Restoration and Repair Jun 23, 2014
Removing foreign paint from clock case? Clock Case Restoration and Repair Jun 17, 2012
Removing Paint from a Gilded Surface Clock Case Restoration and Repair Nov 28, 2008
Removing paint from wooden case Clock Case Restoration and Repair Sep 1, 2006
