Removing a chrono movement from the case
Discussion in 'Watch Repair' started by Paul Raposo, Apr 6, 2017.
  1. Paul Raposo
    Paul Raposo Registered User
    Nov 4, 2005
    706
    I was hoping to get some advice on removing a Landeron 248 chrono movement from it's case. Do I just pull out the crown to the setting position and loosen the screw as per usual, or are there any other steps I need to do beforehand?
    [​IMG]
  2. roughbarked
    roughbarked Registered User
    Dec 2, 2016
    1,768
    36
    Undo the set lever screw until the stem can be removed and simply tip the movement out. Unless of course the case requires that you take it out through the glass, which I doubt in this instance.
  3. Paul Raposo
    Nov 4, 2005
    706
    Thanks much roughbarked :thumb:
    Do I pull the crown out to the setting position before loosening the set screw?
  4. roughbarked
    Dec 2, 2016
    1,768
    36
    I usually don't pull the crown out when undoing the set lever screw. This may cause the yoke lever to slip out of the clutch pinion. Yes to pulling the stem to the hands set position when tightening the set lever screw.
  5. Paul Raposo
    Nov 4, 2005
    706
    Thanks for the tip roughbarked. I think I've been doing it wrong all this time--I pull out the crown to loosen the set screw then remove the crown. Then when replacing it I don't push the crown in all the way, tighten the screw then push the crown in.
Similar Threads - Removing chrono movement Forum Date
1931 Westclox Pocket Ben stem/crown removal Watch Repair Mar 15, 2017
Electric WW Movado crown stem removal Watch Repair Mar 10, 2017
Ronda RH50-51-52 Tag Heuer quartz chrono - how to remove dial Watch Repair May 17, 2015
Chrono small hands removal Watch Repair Jun 4, 2013
Mechanical WW Omega seamaster chrono remove Watch Repair Jan 16, 2010
