Remove Rusted Movement from case.
Discussion in 'Watch Repair' started by cj415, Apr 13, 2012.
  1. cj415
    cj415 Registered User
    Nov 30, 2008
    57
    #1 cj415, Apr 13, 2012
    I am working on a dive watch. It's a one-piece case (open through crystal) and it looks like the seals leaked at some point and there is rust on the movement.
    I removed the crystal and I was able to lift the dial up enough to release the dial screws and remove the dial, but the rest of the movement is stuck in the case back.
    Any suggestions on how to get this movement out of the case. Of course, I want to salvage as much of the movements as possible (as well as the case!).
    Thanks,
    Chris
  2. Lorne
    Lorne Registered User
    Jul 31, 2008
    572
    You can always try Naval Jelly. It will break down the rust but shouldn't attack the metal.
  3. technitype
    technitype Registered User
    Feb 19, 2012
    549
    Electro-mechanical technician
    Frankly, I wouldn't try that- I suspect that Naval Jelly will attack the plate and bridges of the watch...but then, you may have more experience than I have.
    If it were me, I would try ultrasonically cleaning the watch in kerosene- that should not harm what is left of the watch.
  4. cj415
    Nov 30, 2008
    57
    Thanks for the tips... I think I'll start slowly and move up from there. I'll put it in the ultrasonic with just water and then try some L&R Ultrasonic solution. If those don't work, I'll put out the bigger guns.
    Thanks again,
    Chris
  5. zcjaais
    zcjaais Registered User
    Jun 30, 2011
    11
    Amsterdam, the Netherlands
    I've had similar experience with a dive watch. Soaked it in weapons cleaning fine oil over night, then cleaned in zippo lighter fluid. All the rubber gaskets do swell up from the oil, but they were probably faulty anyway. I have also used penetrating releasing oil with success.
Similar Threads - Remove Rusted Movement Forum Date
Removing Rusted Screw Securing Movement Watch Case Watch Repair Jul 28, 2017
How do you safely remove a mainspring from its packing ring? Watch Repair Mar 4, 2017
Mechanical WW Super basic question - remove movement from case Watch Repair Dec 5, 2016
Remove Link From Vintage Kreisler Band? Watch Repair Dec 5, 2016
Remove Wheel Hands Chinese Duplex Watch Repair Sep 15, 2016
