regulator clock strike
Discussion in 'General Clock Discussions' started by trschaefer, Aug 12, 2017.
  1. trschaefer
    trschaefer Registered User
    Feb 20, 2017
    14
    Accountant
    Madison, WI
    I had the attached regulator clock serviced at the local clock shop. It was an eBay purchase. (Prior to having it serviced, it was not running, so I have no reference point for the "pre-servicing" state of the clock's strike mechanism.)
    My question is... When I got it back from being serviced by the clock shop, it strikes the number of the hour on BOTH the hour & half-hour (Example: At 7:00 it strikes 7 times. At 7:30 it also strikes 7 times).
    Is this normal for a regulator clock? My other striking clocks only string a single time at the half-hour. Otherwise it's running beautifully. Thanks, Tom
  2. bruce linde
    bruce linde Technical Admin
    1,775
    take it back to the shop and have them set it up right. it's only supposed to strike once on the half hour.
  3. shutterbug
    34,335
    29
    Lifting too high on the 1/2, and dropping the rack again.
  4. trschaefer
    Feb 20, 2017
    14
    Accountant
    Madison, WI
    How big a fix is this? I am comfortable taking the movement out. (I disassembled, cleaned, reassembled & oiled a banjo clock movement just last week.) Could I make the necessary adjustment? It's such a hassle to drag this enormous clock back to the shop.
  5. John P
    John P Registered User
    Donor NAWCC Member
    Sep 17, 2010
    586
    Looking after the cats
    The problem with repairing it yourself is that it would void any warranty the clock shop provided.
    All reputable shops stand behind their repairs. We all have had comebacks. Sometimes, transporting the clock back home creates issues not seen in the shop, or the owner may have moved the hands during warning.
    I would first call the gentleman who repaired it and explain the striking problem. Give him a chance to correct it before going into it yourself.
  6. R. Croswell
    R. Croswell Registered User
    6,642
    23
    By all means give the shop a chance to make it right. They may be willing to come to you or take it to their shop and return it. Unless there is more to this story than has been told, it's their problem and they should fix it at no cost and minimal inconvenience
  7. trschaefer
    Feb 20, 2017
    14
    Accountant
    Madison, WI
    Thank you for encouraging me to go back to the clock shop. Actually it wasn't a clock shop, but a more general appliance repair shop that ALSO repairs antique clocks. (Hence my hesitation in returning.) When I explained the problem, he knew exactly what needed to be corrected, and made the adjustment at no additional cost. Another lesson that I learned...?? When you get home with a movement that has just been serviced, do not totally reassemble the clock, until you've first verified that the clock shop has successfully fixed the issue!! Thanks.
Similar Threads - regulator clock strike Forum Date
ID regulator clock General Clock Discussions Oct 11, 2017
Marti crystal regulator clock inquiry General Clock Discussions Jul 28, 2017
Howard Miller regulator clock shelburne General Clock Discussions Apr 20, 2017
Ithaca Calendar Clock - No. 2 Regulator? General Clock Discussions Mar 13, 2017
Ingraham Trenton Regulator Clock - Unique Face General Clock Discussions Jan 19, 2017
