Regulation of Hermle 340-020A
MuensterMann
Mar 23, 2008
1,493
19
I replaced the dead movement in my Hamilton mantle clock with a newer Hermle movement. The previous one had a floating balance and the regulation was moving the disk on the spring - and the movement had + and - written on the back plate. This one has a different balance. Is the speed regulation done by the screw as outlined in the image?
Don't mind the bag tie stuck in the wheel. I am using it to stop the balance as I wait an hour! Is there any other method that is more elegant for stopping the balance?
14,276
1,577
A toothpick stuck through a hole in the plate and between the spokes of one of the upper wheels will do it, or a scrap of plastic tubing stuck into any of the winding holes will stop the hand. This is the way new clocks are shipped, so they won't tick.
If you are setting the time back, simply turn the minute hand back (anti clockwise) one revolution. This clock is designed to set backwards.
46,894
1,980
I believe the screw you point to is for setting the rate, as you suspect.
MuensterMann
Mar 23, 2008
1,493
19
Yep, it is the screw for regulating rate. In the right light angle I was able to read a + and - near the screw. Not very big and not very clear - but it is there!! Thanks!
166,934
1,454,680
87,193
Hullah
