Hi,
I have a 1950's German Cuckoo clock i'm restoring. This is my first Cuckoo. I've refirbished the movement. It basically just needed a really good cleaning.
I place it in a test stand and set the beat and everthing seemed fine I thought until after some time went by (no pun intended).
I noticed the chime side wasnt firing off. It worked perfectly when manually tested. I've diassemebed it checked everyting again and again.
Same problem. The hour hand isn't cooperating. Sometimes it moves randomly and stops and sometimes it makes a complete rotation
and at times dosen't move at all. I've even noticed some slippage as it tries to rotate. What I observe is there may be some suttle friction from the
minute hand shaft rotation moving the hour tube.
I'm not very familure with Rack Strikes. This is my second one with years in between. I've read over, several times, the artical written by Bangster.
A lingering question I have is: "What actually drives the hour hand."
I don't see a mechanical drive or wheel that drives the hour wheel.
I do see the lifting cam rotating when I manually turn the minute hand and it activates the rack hook and so forth.
I don't see any mechanical drive for the hour hand shaft tube.
I've also included a pic of the minute hand wheel-shaft
Any thoughts or ideas are greatly appreciated.
