Regula 25 S Adjustment
Discussion in 'Clock Repair' started by Les Sanders, Nov 13, 2017.
  1. Les Sanders
    Les Sanders Registered User
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    I am working on a musical,water wheel and dancers Cuckoo Clock. The complaint was the weight on the music box when wound fell right back to the floor. I enlisted another Clock Repair Person to fix the problem with the click. He did that and went ahead and cleaned and oiled the movement. Pick it up and he said I don't know why but it won't stop cuckooing. So It is my customers clock and I have not worked on cuckoos much. I assume I need to remove the movement and see if I can figure out what I am dealing with before I buy a book on these clocks. What do I need to look for when I have movement out on my fixture? And anyone know which book I should buy?
  2. Chris D
    Chris D Registered User
    NAWCC Member Donor
    Sep 8, 2009
    327
    7
    Coplay, PA
    I'd ask him if he completely disassembled it and if he took off the gathering pallet. It may not be in the right position. You could try to pop off the dial and pull the chain and watch the action.
  3. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    1,355
    52
    Science teacher, writer
    Lancaster, Ohio, USA
    Yes. Take off the hands and carefully pry off the dial, which will be held on by tiny nails that may or may not have heads. You'll then be able to see the rack, the gathering pallet, and the rack hook.. The operation isn't much different from any other rack-strike clock, except:
    If the rack hook doesn't come down after the cuckooing is supposed to have completed then you'll have to figure out why, which is tough because on a music cuckoo there's lots of stuff attached to that rack hook. It triggers the music box, so have a look at that linkage, and it controls the bird. As for said bird, many cuckoo clocks have a hatchway on one side (or both) of the case that gives you access to the bird linkage and other linkages.
    They take a bit of getting used to, but Regula cuckoo movements are actually pretty good quality despite their rustic appearance. There are several different cuckooing schemes, so you'll want to study your movements until you become familiar with their operation. After a lot of trepidation I discovered that they're not too difficult to understand.
    M Kinsler
    and don't forget to unlatch that little door for the cuckoo bird.
  4. shutterbug
    shutterbug Super Moderator
    35,912
    124
    Depending on how much your guy charged you for the repair, I think he should fix this problem for you. If he really cleaned the movement, he took it apart and didn't test it well when he put it back together.
    Bujumon likes this.
  5. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    Well He did not charge me and said he could not fix the clock. The problem was the click on the music box was not catching so the weight would just go right to the floor. I am not even sure why he messed with movement. That being said I have to fix it for my customer. I have a video of what the clock is doing.
  6. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    I have made some progress the cuckoo train not stops however the bird are swings out locks and stays there?
  7. Chris D
    NAWCC Member Donor
    Sep 8, 2009
    327
    7
    Coplay, PA
    Now that you got it to stop... can you post another video of the front please.
  8. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    Will do. The only problem is the bird arm not retracting.
  9. Chris D
    NAWCC Member Donor
    Sep 8, 2009
    327
    7
    Coplay, PA
    Ok, is the pin on the rack hook sitting in the gathering pallet properly? If it's hitting the left side of the pallet it may not be allowing the tab at the top of the rack hook to drop low enough to hit the bird lock arm.
  10. kinsler33
    Aug 17, 2014
    1,355
    52
    There is a wire that extends from the wood flap of one of the cuckoo bellows. Its purpose is to make the bird bob his head as he announces the hour. Make sure that the bird's tail isn't dragging on this wire when he tries to go back in.
    Also check to see if the door is free to swing, that the link between bird and door isn't jamming, and that the bird's head isn't hitting the top of the doorway. If the door seems well-intentioned but unreliable, check the alignment of its wretched little hinges and perhaps apply the _tiniest_ bit of oil to these.
    If the bird pops in and out of the door as he cuckoos there's a problem with the hook that keeps the cuckoo out there.
    M Kinsler
  11. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    Now working with the exception of bird arm will not retract, I even put pressure on it to help but it is locked solid!
  12. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
  13. Chris D
    NAWCC Member Donor
    Sep 8, 2009
    327
    7
    Coplay, PA
    Still looks like the pin on the rack hook isn't falling down into the pallet like it should. What did you do to get it to work?
  14. harold bain
    NAWCC Fellow NAWCC Member Donor
    40,853
    105
    You haven't told us what the fix was.
  15. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    I did the vertical part of the bird shaft was not oiled, I put a couple of drops oil on the mounts and away she went!
  16. harold bain
    40,853
    105
    So is it now working correctly and back in the case, Les?
  17. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    Yes I just finished it this morning. I still have to replace the click on the music box ratchet wheel. Then it will be 100% Thanks to everyone for the input!
  18. harold bain
    40,853
    105
    I thought your other repairman had fixed the click problem.
  19. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    So did I, it worked for a bit and then failed, I took it apart and tip of the click was 90 % worn, I found a source and ordered a new one.
  20. Les Sanders
    NAWCC Member Donor
    Apr 3, 2010
    524
    Clock Repairman
    Sahuarita Arizona
    A haunting cuckoo clock. So I got my new Music Box Chain wheel installed it and it went back to non stop cuckoo action. so I just kept looking and studying all of the aspects of the cuckoo action and as I was looking I noticed the On/Off lever on the other side of the movement was touching the music box lever, so I removed the lever and that was the problem. The part of the lever that pushes on the off rod is slightly bent, just enough to give me grief! Thanks to all who helped me think my way thru this problem.
