regula 25 music before cuckoo
Discussion in 'Clock Repair' started by rick stump, Sep 22, 2014.
  1. rick stump
    rick stump Registered User
    Sep 7, 2014
    13
    sofa test dummy
    hardy va
    How would one adjust for music playing 5 minutes before the cuckoo announces.
    Thanks.
    Rick
  2. Bill Stuntz
    Bill Stuntz Registered User
    Apr 6, 2012
    4,776
    19
    PC Tech
    Columbus. OH
    I don't think it's possible - I think the lever that locks the cuckoo train UNlocks the the music.
  3. Tinker Dwight
    Tinker Dwight Registered User
    13,666
    66
    There are levers that arrange this. We'd need pictures
    of the back of the clock since there are a couple of different
    arrangements.
    It is not an easy adjustment and is difficult for someone that
    has done it. For a beginner is not going to be easy.
  4. shutterbug
    41,739
    912
    In the mean time, I'll move this to Clock Repair for more help.
  5. rick stump
    Sep 7, 2014
    13
    sofa test dummy
    hardy va
    I've fixed many regula 25 movements. This is the first with music. I understand the relationship the music box levers with the clock. Warning wire and pull lever are working properly.
    This has a separate minute hand tube sliding onto a fixed arbor. With the hour tube over that. Possibly the minute tube, since it has a fixed cam gear, may need to be synchronized with regard to its high points. I'm having problems with photo uploads.
    By the way, the star wheel is between the plates.
  6. harold bain
    harold bain Registered User
    NAWCC Member Deceased
    40,850
    148
    deceased
    #6 harold bain, Sep 23, 2014
    Well, if they were working properly, you wouldn't get any music playing til the cuckoo finished its thing. Perhaps you don't understand the relationship as well as you think you do??
    Best I can do is tell you that when the lever is pulled out of the drum during cuckoo warn, there is another wire that has to catch the fly on the music governor to keep it from running until the cuckoo finishes, at which time it drops out of the way. Pictures would help us to see exactly where you need to focus your attention.
  7. rick stump
    Sep 7, 2014
    13
    sofa test dummy
    hardy va
    Knew it well enough to fix the problem. The pull lever on the clock needed a little slack. Figured out the cam gear too. I set the cam at the top of the arc as it held the strike release. Thanks.
  8. harold bain
    40,850
    148
    deceased
    Glad to hear you've solved it Rick. The difference between working and not working is often just a few thou of an inch. Was yours one of the cuckoos with the music movement in the roof? They are always fun to work on.
  9. shutterbug
    41,739
    912
    Your pictures might have been too big. There's a size limit of around 3000 pixels. Try reducing the size and uploading them again so we can see that beast :)
  10. rick stump
    Sep 7, 2014
    13
    sofa test dummy
    hardy va
    Harold, it does have a roof mounted box. I finally figured it out thanks to a post by "Bangster" in 2012.
    Thanks guys.
    I
