Regency Lancet Twin Fusee Bracket Clock (Reid & Auld)
Discussion in 'General Clock Discussions' started by JDCKent, Jan 29, 2017.
  1. JDCKent
    JDCKent Registered User
    Purchased this Regency period bracket clock at auction last year. After spending some time in the shop, it is now home and running beautifully. It turns out that there is a repeating function in the movement, and upon further inspection discovered that the original hole on the side of the case for pull cord had been filled. Anyway are a few new photos of the clock that I thought I'd go ahead and share.
    [​IMG]
    [​IMG]
    [​IMG][​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
  2. novicetimekeeper
    Jul 26, 2015
    4,821
    Dorset
    The bit of engraving on the backplate is nice, this seems to have continued longer with Scottish made clocks,
  3. leeinv66
    leeinv66 Super Moderator
    Donor NAWCC Member
    Mar 31, 2005
    8,000
    12
    Industry Specialist
    Launceston Tasmania
    Beautiful clock! Clean and simple lines and not overly embellished. Just the way I like them.
  4. JDCKent
    Thanks! Apparently it needs a little more help still, because of a runaway strike train at the 1 o'clock position. Don't know for sure what the heck is not catching and stopping it. I'll have to remove the brick of a movement again and closely observe the mechanism to figure out what's going on.
  5. Ralph
    Ralph Registered User
    Donor Sponsor NAWCC Member
    Jan 22, 2002
    4,395
    I would remove your "repeat" cord...and see if that fixes it.
    Ralph
  6. JDCKent
    The clock has been doing this since before adding the cord, so it shouldn't be anything related to that. Seemed to strike and stop at the right number when it was out of the case, so thought it was fine. Put it back in the case, and when 1am came along it was right back it. I've switch it over to silent mode for now, until I have time to take it back out fiddle with it. I'll probably find a little better material for the cord itself, and replace it the next time I work on it. Most that I've come across online have that function, including these examples by Handley & Moore.
    [​IMG]
    [​IMG]
  7. jmclaugh
    jmclaugh Registered User
    Jun 1, 2006
    3,613
    Devon
    A really lovely bracket clock and Regency ones are my favourites. Thomas Reid is a well known Scottish maker who was in partnership with William Auld from 1806 until he retired in 1823, died 1831. He was apprenticed in Edinburgh to James Cowan his cousin in 1762 and was then in London from 1770 and then Edinburgh again from 1781 when he succeeded Cowan.
    Good luck with sorting out the striking.
  8. JDCKent
    #8 JDCKent, Mar 15, 2017
    I was finally able to find the source of the problem with the strike. A piece within the train was bent outward just a hair too far, missing the catch. Now it's back in proper running order. The fret silk had obviously been replaced at one time, and was done very sloppily. I was fortunate to have come across a pristine piece of salvaged 19th century silk velvet. Also found a finer piece of wax cord for the repeat pull that closely matches the fret.
    [​IMG]
    [​IMG]
    [​IMG]
  9. novicetimekeeper
    Jul 26, 2015
    4,821
    Dorset
    can you upload the pictures to the server again please? they seem to have gone
  10. THTanner
    THTanner Registered User
    Donor NAWCC Member
    Jul 3, 2016
    961
    Carson City, Nevada
    My William Webster has the same feature and the cord comes out the bottom with a little brass pull tab. The way mine is currently set, if you pull the string after about 10 till the hour you will get the next hour strike. I am not sure that is correct, but it is the only setting for the snail that lets the one o'clock strike occur properly without catching the tail on the snail as it rises from the 12 o'clock position. I don't think the pull string has anything to do with it, but is more likely that the tail is not dropping onto the one o'clock portion of the snail properly.
  11. JDCKent
    [​IMG][​IMG][​IMG]
  12. prideofmatchingham
    prideofmatchingham Registered User
    Dec 13, 2011
    1,271
    Civil Servant
    Kolkata, India
    #12 prideofmatchingham, Mar 17, 2017
    As the lever is to be pressed downwards for repeat to be activated, my hunch is that repeat hole should have been lower. That also is the case with my clock. Hole being so high up, almost in line with the mechanism, would exert sideways pressure on lever rather than downward.
    Unless ofcourse thats the way it was designed.
    Glad that silk has been replaced with the current red one. Makes it 'hot'!
    By the way, there seems to be a hole on the lower portion of the movement backplate. Possibly that is the place where brass pendulum movement lock was there along with the stabiliser knob. Possibly that explains another vacant hole on the movement support brass L where this knob fits.
  13. JDCKent
    It appears to be in the right spot, after examining how the mechanism operates on this particular movement. The loop that's attached to that release pull is angled far enough upward and back to where I believe a lower placement would require more force. If I pull out and downward somewhat on the string when activating the repeat, it seems to operate quite smoothly and easily.
    I'm glad you approve of the fabric replacement and color choice. I looked at several other period examples online, and most had a red or maroon/wine-colored silk that was similar. It does seem much more appropriate for the clock, and certainly more attractive. I just didn't want to replace it with brand new fabric, although what I found is probably not quite as early as the clock itself. Probably Victorian.
    Hopefully at some point I'll be able to locate a correct-fitting pendulum lock and knurled thumbscrew though for that backplate.
  14. JDCKent
    #14 JDCKent, Apr 5, 2017
    Was happy to recently find a copy, and first edition no less, of Reid's Treatise on Clock and Watchmaking. He also mentions his late partner William Auld in the preface. Interesting book! Surely not the finest example, but does still have all of the foldout plates attached near the back.
    [​IMG][​IMG]
Similar Threads - Regency Lancet Twin Forum Date
English twin fusee dial clock, dating and any additional info please General Clock Discussions Apr 26, 2017
Twin fusee Full Westminster Chiming Clock General Clock Discussions Jul 8, 2016
Gustav Becker twin weight wall clock General Clock Discussions Dec 12, 2015
A Rare Beha Black forest exposed bird cuckoo, 8 day, twin fusee table clock. General Clock Discussions Nov 22, 2015
