Refinish old clock
Discussion in 'Clock Case Restoration and Repair' started by Grandpa, Jun 22, 2007.
  1. Grandpa
    Grandpa Guest
    A old wall calendar wall clock came in yesterday. I have not openend it up yet so I don't know who made the clock.
    The customer asked if I could refinish the wood on the clock. The finish looks to me like a shilack. It is dirty and bumpy.
    My question is what do you use to clean the wood and what do you use to re finish it?
    Thank You
    Gramps
  2. Patrick R
    Patrick R Registered User
    Jun 22, 2006
    348
    Hey Gramps, I have been told that the Natchez Solution works well for cleaning any wood surface. I believe TimeSavers has this. You will have to ask someone elese about re finishing it.
    On black wood cases some people use black shoe polish, its cheap and goes a long way. And I think you might be able to use high gloss black enamle paint. Im not sure if that is used on Black Iron cases or wood cases, I think Iron.
    Good luck Gramps.
    Pat
  3. Jim D.
    Jim D. Guest
    Gramps,
    Can you give us a photo or two? A lot depends on the finish and condition as to how to go about it.
    Jim D.
  4. Grandpa
    Grandpa Guest
    I have to go to the Doctor today, so I will try and get a picture tomorrow.
    The clock it self is in pretty good shape. Its just the finish is old and getting bumpy. I have seen a lot of varnished wood look like this and would sanded it off and re varnish. I was hoping to save all that. I'm not sure, but I don't think its varnished.
    This clock was the owners Grandmothers and he remembers it as a child hanging on the wall.
    I have serviced 2 of his other clocks, one was a grandfather brought over from Germany with no name on it and the other is a Becker wall clock. He takes very good care of his clocks. If he didn't I would not have taken on the project.
    I'll get you some pictures as soon as I can.
    Thanks for all the help.
    Gramps
  5. Joseph Bautsch
    Dec 9, 2006
    573
    Atlanta, GA
    Gramps - Take a soft white cloth. Cotton is best. Wet it with alcohol and rub an inconspicuous spot on the finish. If it is shellac a little of it should rub off on the cloth. It should not be enough to damage the finish as is. If it's varnish all that will come off will be some dirt. A shellac finish is easier to re-do than varnish.
  6. Grandpa
    Grandpa Guest
    Thanks Joseph,
    I'll give er a try in the AM.
    Gramps
Similar Threads - Refinish clock Forum Date
Ansonia "Fortunia" Swinger clock - I need advice on how and whether to refinish it. Clock Case Restoration and Repair Sep 7, 2013
1960's Bulova Desk Clock refinish--I can't seperate the glass from the brass bezel?? Clock Case Restoration and Repair Aug 5, 2012
HELP: who can refinish an Ansonia statue clock Clock Case Restoration and Repair Oct 19, 2011
How to refinish a Gallery clock case?? Clock Case Restoration and Repair Jul 21, 2011
Refinish this art deco mantle clock Clock Case Restoration and Repair Dec 14, 2009
