Refilling a Slate (?) dial
f.webster
Dec 18, 2009
1,028
111
Louisville, KY
I have this French clock that I am restoring. Some have suggested that the dial is slate. It looks to be engraved and filled with gold paint (?). I would like to clean the old out and refill the numbers etc. Please give you advice and wise counsel.
Thanks in advance.
f.webster
Dec 18, 2009
1,028
111
Louisville, KY
50+ views and no suggestions. Well, let's just figure it out.
First you have to take the dial apart and see exactly what we are dealing with.
demoman3955
Apr 9, 2022
616
215
66
too many differing opinions, and im far from knowing anything about that topic, but i like the face as it is, but i dont like a new looking clocks anyway. Id try doing a search on the subject, because ive seen photos of it being done somewhere.
f.webster
Dec 18, 2009
1,028
111
Louisville, KY
Do the things you know how to do. So, after carefully taking the dial assembly apart, I cleaned the metal pieces. Still doing the research necessary to feel confident addressing the slate face. I have re-silvered dials and am thinking the process will be similar yet not exactly the same. I have also filled engraved lettering on pocket watch bridges. Another process like I am considering.
Comments?
gmorse
15,242
4,360
Hi f.webster,
It looks more like marble than slate; most of the black French mantel cases described as slate are actually made of marble, which takes a very good polish. The gold coloured incised lines on these marble cases can be restored with a gold felt tip marker and any excess scraped off before it dries fully with the edge of a credit card. This produces a clean result and I see no reason to expect that this marble dial would be any different. A bonus is that it's reversible if you don't like the finished effect.
f.webster
Dec 18, 2009
1,028
111
Louisville, KY
With what I have been reading, I plan on cleaning and polishing before I try to fill the etched numbers etc.. Once I am happy with the results, I am thinking of sealing it with something (?).
Thanks for the input Graham
Support the NAWCC
Forum Expense plus NAWCC
Goal
$1,000.00
Received
$360.00
36%
Host server
$250.00
Software support
$250.00
NAWCC operations
$500.00
Expenses
Staff online
181,318
1,582,086
54,765
Hec Losame
3,126
Top
