Reed switch for Jaeger clock (1941 6-volt car)
Bernhard J.
Jan 10, 2022
1,581
1,615
Berlin, Germany
Just for my interest, you are sure that it is a Reed switch? Reed switches as to my knowledge became more or less widespread end of the 40s only (but I may be wrong).
What does it do?
Sorry for questions instead of information, but I do not have an idea where to look. I case of an "unobtainable" microswitch for a car I spend days looking through catalogues and comparing and just by coincidence found out, that a microswitch from another make is 100% identical with the one I needed.
Best regards, Bernhard
Charles Be Ville
May 5, 2020
Thanks for your reply. It's a single lightweight contact that is hooked to the coil and gets a ground signal through a pin that oscillates attached to the balance wheel. It was used in American and European cars. I have seen a lot of them. I thought it was a reed switch, but after your response, I looked at HSI Sensing website and it doesn't match their description although they say that the first reed switch was patented in 1936 and hit the market in 1940. However, the case of the Jaeger car clocks may look different , but the inside is the same as the regular clock. Do you know of any other manufacturers that might make anything similar? Again, thanks for the info.
Charles Be Ville
May 5, 2020
I am still looking for a Jaeger switch and have attached another photo that shows the part I need (it's orange) with Jaeger written on it. Does anyone have one they can part with?
Staff online
181,391
1,582,702
54,791
LSZ
3,130
Swiss Fake by Kent
Top
