Reconstruction
Discussion in 'General Clock Discussions' started by amzgraz, Nov 19, 2019.
  1. amzgraz
    amzgraz Registered User
    Feb 19, 2018
    141
    Rancho Cucamonga, California
    I purchases and received a marble clock which was damaged. It had actual broken pieces as well as pieces that had become seperated from the marble case. The several pices were eithe pasted. glued, mortared, or ? together. Does anyone know what material was used for the assembly. I seems to a cream colored cementatious product from the early 1900s.
    thanks
    amzgraz.
  2. wow
    wow Registered User
    Jun 24, 2008
    4,136
    291
    Retired Music Minister
    Pineville, La. (central La.)
    I do not know what they used, but I have reconstructed several of these and have found a product that will work very well on them. It is available in a caulk tube which is ideal for those projects. It sets up fast and cannot be separated once it sets.its called F26 construction adhesive by Leach.
  3. Uhralt
    Uhralt Registered User
    4,850
    575
    Originally they used plaster of Paris for this. The problem with it is that is doesn't stick very well. I think that wow's suggestion is a good one.
  4. rickyn
    rickyn Registered User
    NAWCC Fellow NAWCC Member
    Jul 7, 2009
    106
    retired masonry contractor
    Binghamton,NY
    I have used plastering gesso. It worked real good. The veins of my clock are gold color. So I put golden colored powder in it . When I finished and shined it. It looks like the other veins that where there. Rickyn.
  5. amzgraz
    Feb 19, 2018
    141
    Thanks again for your suggestions. the easiest was a bube of construction adhesive. Worked great.:p
