Recommended oil for Ansonia Andes mantle gingerbread clock?
Discussion in 'Clock Repair' started by Darkstrike, Aug 4, 2019.
  1. Darkstrike
    Darkstrike Registered User
    Aug 4, 2019
    20
    I did some more research and learned that my free gingerbread mantle clock is an Ansonia Andes from roughly 1906.
    I ran it for a day to see if it kept time and it seems to work perfectly! The timekeeping has been spot on perfect and the chime has gone off perfectly on the hour and half hour.
    However, I want to clean and oil it before I start using it again after my brief test run as the previous owner had never used it (thinking it was broken?) and I have no idea when it was last oiled or cleaned.
    Does anybody have a suggestion for an oil to use? I've been researching and many different sites recommend many different things...
    Cheers and thanks!
  2. Uhralt
    Uhralt Registered User
    4,045
    413
    A synthetic oil like Mobil 1 works well on these movements. You can also use commercially available clock oil, but it is more expensive and doesn't offer much more.
  3. Darkstrike
    Aug 4, 2019
    20
    Thanks for the reply!
    Is there a certain blend of synthetic oil that works best? 5W40? 5W30...?
  4. Joseph Bautsch
    Dec 9, 2006
    1,113
    123
    Atlanta, GA
    The oil should be 100% synthetic. Any weight will do. Thin out the oil to the consistancy needed with a solvent.
    Darkstrike likes this.
  5. Willie X
    Willie X Registered User
    12,181
    749
    Use Mobil-1, 0W-20 or 5W-20. Reducing an oil's viscosity with a solvent is a questionable practice. Willie X
  6. Darkstrike
    Aug 4, 2019
    20
    #6 Darkstrike, Aug 4, 2019
    @Joseph Bautsch - Thanks for the info...not sure I'd feel comfortable with using any amount of solvent on 110 year old brass though!
    @Willie X - Thanks, any particular reason it has to be Mobil 1 brand, would full synthetic from another brand do in those two viscosities?
    Cheers and thanks again to you all for the help!
  7. Willie X
    12,181
    749
    Yes, whatever brand that floats your boat will be fine. :)
    Solvents won't hurt brass. If they do? I've hurt a lot of brass in my day!
    Karl Thies likes this.
  8. gmorse
    gmorse Registered User
    10,642
    1,272
    Retired from Xerox
    Hi,
    I'm with Willie; when the solvent evaporates, the oil will be back close to its original viscosity, so what's the point in diluting it in the first place? Plus the oil may have migrated more than it should, due to the reduced viscosity.
  9. JTD
    JTD Registered User
    Sep 27, 2005
    6,786
    361
    Why not just buy some clock oil from a reputable supplier? Easy, cheap and far less trouble.
    Maybe it's just me, but that's what I think. We're dealing with a pretty straightforward movement here.
    JTD
  10. R. Croswell
    R. Croswell Registered User
    9,507
    602
    My own somewhat unscientific tests (time required for the same quantity of oil to flow by gravity alone through a applicator needle) indicated that Mobil-1, 0-W20 flows more slowly than Nye-140 clock oil. For most clocks I felt that Nye-140 was OK but a little thin. Then there were discussions here based on some limited factual evidence that supported the conclusion that perhaps the common clock oils may actually have lower than ideal viscosity. The 0-W20 engine oil seemed like it would be a good possibility being significantly thicker than Nye-140 and about the lowest viscosity synthetic engine oil generally available. I tried it and was impressed with the results but still have some reservations about some of the cladistics of oils optimized of non-clock uses. It would appear however that the anti-wear and anti-friction additives perhaps offer a greater advantage than any disadvantage from additives that reduce surface tension and help the oil to flow and retain dirt for filtering in an engine.
    Why Mobil-1? For me the main reason is that's the brand that is mostr often discussed here and I believe the brand that many here have reported having success with. I once tried a Ford brand synthetic blend and was not impressed. There have been a number of past arguments against using engine oil in clocks, but as far as I can remember I have never heard anyone say that they have had an oil related failure using a Mobil-1 oil of one of the viscosities typically used in a modern engine. That by no means implies that other brands of full synthetic are any better or worse.
  11. Willie X
    12,181
    749
    The 0W-20 oil was not available until 2011. I bought a 2011 Toyota and had trouble finding the recommended 0W-20 in time for it's first oil change. No break-in oil change and 10K miles between changes for that one. Willie X
  12. Uhralt
    4,045
    413
    #12 Uhralt, Aug 5, 2019
    I think simply because it was the first readily available fully synthetic oil.
  13. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,016
    366
    Welcome to the NAWCC Message Board Darkstrike! I think you'll find that you've come to the right place to get good information on the care and feeding of your antique clocks.
    It can get controversial around here at times as there are strongly held, sometimes differing opinions on even some of the most basic of things. There usually is a general consensus though.
    The Message Board's Search Engine is pretty good at returning content you're looking for as can be Google (when you tell it which site to search). The Message Board's Archives are a treasure trove of good advice if you have the time to search through them while taking in the bigger picture.
    Then you'll have all of the members here with decades (cumulatively...centuries) of experience to help guide you.
    Now, when you say "clean and oil", what exactly do you mean by clean? :emoji_skull_crossbones:....:chuckling:
    As far as oil goes, I'm in general agreement with comments/advice already given.above
    Personally:
    I use Nye Synthetic Clock Oil for applications requiring a low-viscosity lubricant.
    For general applications I use Mobil-1 5W-30
    For high viscosity applications I use Castrol Edge Gold 10W-60
    You won't go wrong with a good, name brand synthetic clock oil. It will be more expensive than motor oils but you're not using that much of it per clock. A relatively small bottle will still go a very long way if you don't spill or otherwise waste any it. The little bottles are easily knocked over if you're not careful.
    Be sure to look around and browse through the collection of articles that bangster has assembled in the "Sticky Threads" located at the top of the Clock Repair Forum's Home Page.
    For your convenience here are two such Thread/Articles on oil that I would like to draw your attention to:
    http://www.kensclockclinic.com/wp-content/uploads/2015/02/Clock-Oils.pdf
    Mobil 1â„¢ 15W-50 full synthetic oil at Walmart. $6.95/qt.
    Have fun and hope to see you around.
    Bruce
  14. Darkstrike
    Aug 4, 2019
    20
    #14 Darkstrike, Aug 6, 2019
    @JTD - I wouldn't say less trouble, or necessarily cheaper....conveniently, the suggested 5w20 synthetic motor oil people have suggested is exactly what my car requires, so I actually already have some around....can't get cheaper than something I already own! :p
    My issue is that I am new to this, so even if I went the clock oil route, I don't know what suppliers or brands of clock oil ARE reputable!
    @R. Croswell - Thanks for the info!
    @Time After Time - Thanks for the warm welcome! When I said 'clean and oil' - I meant removing the movement, hopefully NOT having to take it COMPLETELY apart, and trying to gently wipe any dirt or crud off that I can see on any of the pinions, gears, etc with a qtip, or soft cloth, oiling all the bearings back up (and the springs, somewhere I read that I should oil those as well...?) and putting it back together! :) I'd actually found, saved and read that article on Ken's Clock Clinic on oils...informative! That's the main thing I'd found that made me consider using motor oil for my clock, especially as my car already uses 5w20 and I already have some full synthetic of it here at home. Would I be able to put that on the mainsprings as well, or should I be using something different for those? This isn't a large clock, just your usual mantle gingerbread clock. :)
  15. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    You won't go wrong with that Darkstrike, just be sure to use fresh oil out of the container and not any of that used stuff out of the oil pan. :chuckling:
  16. Darkstrike
    Aug 4, 2019
    20
    Haha, for sure! I was editing my post as you replied, so there may be some other stuff in there you hadn't seen. :)
    Do I just use a dab on a toothpick to apply it to the bearings?
  17. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    #17 Bruce Alexander, Aug 6, 2019
    Okay DS, cleaning is a whole 'nother argu..er, debate. If you're serious about working with clocks, you will have to learn how to disassemble and reassemble their movements. There is absolutely no good way around that fact.
    If, however, you just want to kind of get your feet wet first, some advocate the use of so-called "Intact Cleaning" methods.
    I think this Intact Cleaning method is pretty good, but it requires a solder sucker. In the absence of a solder sucker, I suppose you could add more "reps" and substitute cotton-tipped applicators.
    Regarding the use of a toothpick as an applicator, for just starting out, sure...keep in mind that too much oil is almost as bad as not enough. Too much oil will run out of the oil sink/bearing and draw most of the oil with it. Too much oil also attracts dust/dirt.
    Bangster has an online tutorial on the subject. Please see: Oil a clock, How To (5 pages) •
    I'll be "Watching". Have fun and don't hesitate to let us know when you have more questions.
    Bruce
    Edit: You asked about Mainspring Lubricant. Lots of differing opinions on that as well. Very generally speaking, you'll want a heavier viscosity lubricant for your mainsprings. Some folks will apply a light grease. Again, use the oil you have on hand. It will be better than nothing to start with. You'll have a difficult time properly cleaning and lubricating your mainsprings without taking the movement apart. Do the best you can and mentally stick a pin in it. You'll need to come back to the issue later. Others may have more helpful advice...
  18. Darkstrike
    Aug 4, 2019
    20
    Just posting an update - I had ordered a #6 key online from Ebay as to my best measurements (without a caliper!), that was the size key my clock would take.
    ...turns out the one I ordered does not fit, so I have ordered a #7 (4mm) key....hoping that does the trick!
  19. shutterbug
    41,133
    790
    Look at Timsaver's items 10092, 10093, 10094, 10010, 10011, and 10012. They are VERY handy to have for sizing clock winding arbors and for sizing existing keys!
  20. R. Croswell
    9,507
    602
    Be aware that there are American and Swiss key sizes. A #6 American and a #6 Swiss size key won't be the same. My experience with new keys offered by the popular suppliers is that the sizes are not always consistent. Two keys with the same number, one may fit and the other may be tight. Then sometimes the winding arbors may, for whatever reason, not be what they are supposed to be with one being somewhat larger than the other. The tools mentioned by Shutterbug I do find helpful.
  21. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    You won't go wrong with the specialized measuring tools that Shutterbug cites above. They are fast and accurate.
    I keep an even and odd set nearby, but I use them mostly to wind movements that I'm working with. There's no case or dial to get in the way.
    They are less expensive and much handier than buying a bulky set of keys (Don't ask...:rolleyes:).
    I do suggest that if you don't have a good Micrometer, you should look into getting one of those first, Once you can accurately measure the winding arbor or key socket, you can reference this chart: Key Sizes I agree with Shutterbug and RC, if you're going to work with a wide variety of clocks, you should consider purchasing the specialized measuring/winding keys. The more you use them, (and you'll use them a lot) the more they'll be worth the cost to you.
    Bruce
  22. Darkstrike
    Aug 4, 2019
    20
    Thanks for the info gents....I carefully tried to use my new key once again. I can get it onto the gong winder with very little force *IF* I have they key positioned a certain way. It does SLIGHTLY fit over the time winder, but nowhere near as well as the gong winder. So, it DOES seem I have the correct size, but maybe the key isn't perfectly machined...? Or maybe the square winders for the gong and the time are actually slightly different sizes to one another?
    I did order another key in the next size up, so hopefully that does the trick!
  23. Uhralt
    4,045
    413
    The winding arbors are often not identical. They may have been filed in the past to remove rounded shoulders. I set of needle files is rather inexpensive and can solve problems like this easily and is useful for may other tasks.
  24. kinsler33
    kinsler33 Registered User
    Aug 17, 2014
    2,993
    274
    Science teacher, writer
    Lancaster, Ohio, USA
    I'd suggest that, if the clock is running perfectly, that you leave it alone and let it continue to run perfectly. I haven't seen any evidence that preventative maintenance is of any particular use in a clock. It's important in a high-speed mechanism like an engine, but things happen so slowly in a clock's life that nobody ever lives long enough to know what works and what does not.
    It's also not particularly satisfying to work on a clock that's already working well, for your work cannot lead to any improvement in its performance and it's possible that, as a newcomer, you might make things a bit worse. There are plenty of non-working clocks to work on. If you wish to fix clocks your next stop should be to order a catalog from Timesavers.com, which sells lots of the weirder tools and supplies one would need. The less-weird tools and supplies are hardware-store items--I prefer Harbor Freight Tools for most stuff.
    I'd also suggest that if you'd like your life to be happy and peaceful upon the land which the Lord thy God giveth thee that you never ask anybody about anything having to do with clock oil. Also, WD-40.
    M Kinsler
  25. mauleg
    mauleg Registered User
    Dec 26, 2012
    848
    138
    Order a catalog? Like, as in paper? Much faster and easier to just find it on the website or google it with the site: parameter.
    In addition to Timesavers:
    Clock Parts - Clock Movements : Clockworks
    Ronell Clock Company
    Merritt's Clocks & Repair Supplies
    Butterworth Clocks, Inc. - pw:butterworth
    black forest imports.com
    Mile Hi Clock Supplies
    And while I'm poking the Luddite masses: WD40 Rocks! :devil:
  26. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    A clock in good working order with an unknown service history may still need to be properly cleaned and lubricated. For me, there have been numerous occasions where I was tempted to just oil a movement and call it good. I decided, however, to take the movement apart for a proper cleaning and found issues early, like rust on pivots for example. Also, when you're just learning, sometimes it's a useful learning experience to take a working movement apart, service it and get it put back together again. There are situations where it is perfectly acceptable to simply re-oil a movement after careful examination. In brief, if there are no signs of significant wear, no accumulation of dirt or deposits around the pivots and the pivots are not dry it's "okay" to draw out the old oil and replace it with fresh oil for preventive maintenance.
  27. Darkstrike
    Aug 4, 2019
    20
    I haven't oiled it since I got it, I took it apart to see if things SEEMED OK (not being a knowledgeable clock guy, but I am a tinkerer, so knowing how a clock works isn't too much of a stretch for me).
    I have had it running straight-time (with the face and hands off) for the last day just to see if it seemed to keep time and gong properly. I was told when it was given to me that it was 'broken', hence why I've been cautious with it. When I took it apart the first time, though, I didn't see anything wrong with it and the movement looks remarkably clean. Lo and behold, with it running straight time for the last day with the face and hands off, it has been keeping near spot-on perfect time....gonging properly the right time on the half hour and hour as it should (it just went off for the 7:30pm half-hour chime as I write this! :) )
    It SEEMS to be working just fine to me? My only issue, and pardon the stupidity of this question, is that I have no idea how much to wind it. I'd only done like...one full turn or two on each winder as I have no idea how much they were wound when it was given to me. I DO know the gong spring must've run out earlier today, so I did maybe....3.5 full turns of the key to it this morning to wind it up again a bit and it's been fine since....? I will say the gong seems more 'eager' to chime when it is time for it to chime than it had been, so I am guessing the mainspring for that didn't have a lot of tension until now when I had to re-wind it a bit earlier today.
    I know this is an '8-day' movement, supposedly...but how many turns are sufficient to achieve that once one of the mainsprings is wound down to nothing? Should I let the clock keep going until the gong and the time springs are completely slack and then wind it up so I know for certain how much to wind it?
    A picture of the movement once again to show how clean it is....also, none of the front bearings look worn to me, and I've tried to gently 'jiggle' some of them and nothing seems to have undue wear:
    I HAVE NOT removed the movement from the case to look at the backside yet though, but if the front is in seemingly this good a shape, I can't imagine the back would be much worse?
  28. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    You just wind until you can't wind anymore. You don't need to use a lot of force. You'll be able to tell when the mainspring has been fully wound. You can count if you'd like. Some folks count to keep the mainsprings in the middle of their torque range....not too tightly wound, not too far unwound.
    Come on Darkstrike...You should do at least that much. It's really easy! :)
    You can't see (or properly oil) the bearings in the back plate without removing the movement. Areas which are not easily accessible will often be the most neglected.
  29. R. Croswell
    9,507
    602
    Well it looks like the second pivot hole above the winding arbor on the strike side is pretty gooped up and probably has wear that will be more obvious after it is cleaned. Its the dirt in the pivot holes tht can't be seen while the movement is assembled that is usually the problem, not surface dirt on the plates and gears.
    Yes, please go ahead and take it out of the case and let us see the back side.
  30. Uhralt
    4,045
    413
    Time after Time's advice is sound. Wind the springs fully. A typical American 8-day movement usually takes 14 half winds (7 full winds) after a week of running.
  31. Kevin W.
    Kevin W. Registered User
    21,802
    239
    Darkstrike your clock would benefit from a proper clean and oil, why run it more it will just wear quicker with the black gunk around pivots. Depending where you live in Canada i would buy from a Canadian source, as you know our dollar is doing poorly.
  32. Darkstrike
    Aug 4, 2019
    20
    I intend to do so in the next few days! Have to pick up some 5w-20 full synthetic, as I don't have any here at home at the moment!
    Will do! Sometime in the next day or so!
    OK, thanks for the info. That's good info to know, and what I was looking for! I've not honestly wound one before until now, so I have no physical reference to how much effort it should take to wind when it's getting tight, so I had no idea if it was already wound a fair amount or not! :)
    Weird question - is there any benefit to NOT winding them fully all the time (say, only winding them 7/8ths of the way)? Does leaving them a little slack mean they'll last longer or anything of the sort? I'd have thought winding them to max every time could stretch the spring over time or some such...? Forgive my ignorance!
    I know it would, and I intend to do one! I was only running it straight time for a day or two without cleaning it as in the grand scheme of things that shouldn't hurt anything more than it may or may not already be done (everything looks in great working order though) and I was told it 'didn't work' when I was given it, so I wanted to actually see if it worked properly by letting it run that long. It's been about a day and a half now and it seems to work perfectly, so now I'll go through with a proper cleaning! :)
    Kevin W. likes this.
  33. Uhralt
    4,045
    413
    This is not a weird question at all. There are indeed clocks that are made to do just this. They have, what is called "stop works". It prevents the spring to be wound fully and to be fully unwound. Therefore only a part of the spring's power is used where it is relative even over time. The extremes, fully wound and fully unwound are not used. This makes the clock keep better time and there may also be and advantage with regard to wear because the peak power of the spring is never used.
  34. Darkstrike
    Aug 4, 2019
    20
    #34 Darkstrike, Aug 18, 2019
    Thanks for the info! I have no idea if my Ansonia has this or not, but assuming it doesn't!
    Quick update - took the movement out this casing morning before I left for a short job. Here are some pics! Thoughts? :) Pardon the crappy camera-work....the camera is a hi-res Nikon DSLR, but it's the stock lens which is crumby at Macro shots. You might have to download and save them to view them in the greatest detail!
    I see a few bearings from the outside which may need a little cleaning, and a few spots on the inside but it doesn't look too bad to my eyes overall?
    DSC_0015.JPG DSC_0016.JPG DSC_0017.JPG DSC_0018.JPG DSC_0019.JPG DSC_0020.JPG
    One thing that I GUESS is normal, but looks really out of place...on the top of the movement in that last picture, the pin that runs through the clock on the left that holds the movement together, there is a small wire wrapped around it slightly that runs down to the armature that counts how many times the gong goes off on the hour and half-hour wheel...? Guessing it acts as a spring, but it looks like a really weedy spring...is this normal? ('Spring/wire' highlighted in first picture, the armature it's connected to highlighted in the second)
    Will I need to take the entire thing apart to try and clean it, or would I be able to try and clean it as best I could with something like Q-tips and a solder plunger to try and remove any gunk or debris?
  35. R. Croswell
    9,507
    602
    The helper spring is normal. If the strike train is working, observe how it works carefully before taking the movement apart. Not especially the position of any wheels that have stop pina. Yes you should disassemble for cleaning. But make sure you know how to restrain the springs first. Most good books on basic clock repair explain how to do this.
  36. Darkstrike
    Aug 4, 2019
    20
    I could try getting a book, though I know I'm going to need some specialized tools if I were to try it myself (spring clamps)....will those be costly and hard to find? The nearest clock shop from me is over an hour away if I wanted to get it professionally cleaned. :(
    There WAS a gentleman who used to do clock repairs around here, but he passed away a few years ago. I work with his daughter...maybe I should contact her and see if anybody every took up his business when he had retired...
  37. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    Hello again Darkstrike,
    We don't know what your mechanical aptitude is, or what types of tools you have on hand. It really comes down to what you want to do as well as what you feel comfortable attempting. Your clock is not particularly complicated, but you will need some items and tools to work safely with it if you want to take the movement apart to clean and service it. There's no rush. Your clock will patiently wait and clockwork demands patience along with plenty of persistence from you.
    Here is a thread that discusses the types of tools used in a modest shop: recomended Clock repair tools No doubt there are others.
    There are several good books to get you started. There is a LOT of useful information in the archives of this Message Board but it's not ordered and indexed like a book is so it can be confusing for a beginner.
    One excellent way to search the Message Board Archives for answers to questions can be found here: Searching the Message Board using Google
    See this thread on self-guided resources for clock repair: Self-Guided Resource for Clock Repair?
    Of course, you can always ask questions if something is not clear to you, if you get "stuck", or if you want to discuss something before attempting it.
    You've taken the movement out of the clock so you could carefully pack it and ship it to a clock shop for servicing if necessary. It will cost a lot less than shipping the entire clock and there is is probably less risk of shipping damage.
    You could also perform the intact cleaning method I outlined for you in post #17. It's far from ideal but I think it's a lot better than just re-oiling the movement as it is before putting it back into constant operation.
    I'd like to recommend that you review your entire thread. There are a lot of good suggestions from quite a few members of the Message Board here.
    You're probably busy living your live and making a living. Give it plenty of thought as time permits and decide what you want to do. We can try to advise you of your best options based on the information you provide.
    Good luck and have fun with it.
    Bruce
  38. R. Croswell
    9,507
    602
    On this open spring Ansonia all you need to restrain the springs is some steel wire. #16 rebar tie wire available at most building supply places is inexpensive. I have used #18 suspended ceiling wire as well. This clock likely has 0.018" thick springs and #18 wire is on the thin side, #16 (heavier) will be safer. You will need a "letdown key", probably a No. 6 or 7, or you can make one using the clock's winding key and a piece of old broom handle with a hole drilled in the end and a slot cut to fit the wing of the key. The most difficult task will be rewinding the spring after you clean it. The safest and easiest way is to use a "spring winder" tool, which can be expensive to buy but one can be made. You can even assemble the clock with just one main spring arbor in place (and the spring), wire tie the wheel so it can't move and wind the spring into the movement. Then wire tie it and remove it and do the same for the other spring. Then the movement can be reassembled. This is the same movement as my first clock back in 1967. I didn't have any clock tools, no knowledge of clocks, no books, and no one to ask but I got it apart and back together and right now it sits in my living room and is running just fine. The right tools make it a lot easier and safer but it doesn't need to be expensive to begin with just one clock
    You might ask the daughter of the old clock repairman what happened to his tools and if she still has them, perhaps you could purchase of borrow them.
  39. woodlawndon
    woodlawndon Registered User
    Jan 18, 2017
    622
    122
    Woodlawn, Ontario
    Whereabouts do you live in Canada Darkstrike, just wondering if you're close to me.
    Don
  40. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    Impressive. Is that when you decided that you wanted to be a Horologist when you grew up RC? :)
  41. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    I hope my comment didn't come across as flippant. That was an impressive achievement in my "book". I think that I do possess some degree of mechanical aptitude, but I'm not so sure I could have accomplished what you did there RC without some sort of reference material. Which brings us back to what Darkstrike feels comfortable attempting. Let us know where you want to go and if you have any questions on how to get there DS. There are a lot of very experienced, helpful folks around who can assist you...obviously.
  42. R. Croswell
    9,507
    602
    No, not at all. My first "business" was Bob's Radio Repair when I was about 14 or 15. When I graduated in 1960 I went to work for a local electronics manufacturing company, then a larger manufacturer. I became friends with the machinist there and did a little work in the machine shop. Always liked making and fixing things. In 1967 I enrolled in college for teacher training. It was then that I discovered that a friend had this old Ansonia LaFrance in an old abandoned school bus with a lot of other interesting junk. After some conversation I learned that my friend, who was considerably older than me had acquired the clock from my great, great grandfather. So my friend gave it to me. I had no interest in becoming a horological at all. I just wanted to fix the clock and make it go because it had been my family and lost and then found. It was a mechanical thing so I just set about to fix it. It had a broken main spring at the inner coil, so just made a new inner coil and put it back together. No one to tell me not to fix broken inner coils or that it can't be done with the tools I had so I guess that was an advantage. My friend gave me another clock that same year and I fixed that one and still have it. I liked old mechanical things but no interest in doing clock repair except for myself because I couldn't afford to pay anyone. College was an expense. Got the degree and spent 18 years teaching and enjoyed all I could stand of that. Took up welding, repairing food processing equipment, became a licensed water and wastewater treatment plant superintendent, got elected to local office three times and "retired" and started again to collect and fix clocks.
    Not sure what I want to do when I grow up, or if I even want to grow up.
  43. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    Whoa. That's quite a diverse work history. Our son went into Civil Engineering and after earning a PhD decided it wasn't for him. He has a friend who ventured into the work force after earning his Bachelors. He went to work in his father's company in Waste Water Treatment. The Company's motto was, according to the son, "We're No. 1 in the No. 2 Business". :chuckling:
    As far as our son is concerned, he decided he would like to try his hand at becoming an author. He did go back to a part-time Civil Engineering job however. He works for a company dealing with Cell Phone Towers. Those things are everywhere so he should have some job security for a while...even if he does find the work to be boring. He's a character.
  44. Kevin W.
    21,802
    239
    Darkstrike, do you live near a NAWCC Chapter perhaps.
  45. Darkstrike
    Aug 4, 2019
    20
    Mahone Bay, Nova Scotia! :)
    I didn't think it was flippant at all! I actually have a co-worker whose husband apparently does clock repair, so I am going to pay him to clean and oil the movement this time around, but he said I could pop in and watch a bit in case I wanted to try it myself the next time! :)
    No idea....no idea where the nearest chapter is, haha!
  46. Darkstrike
    Aug 4, 2019
    20
    Hi all, an update and a minor question! I have now got my clock back from the husband of a co-worker that does clock repairs and maintenance - all nicely freshly cleaned and oiled! :)
    Now...when I'd given it to him, I'd only given him the movement and hands, nothing more...as I had already had the movement out of the casing to check it for damage and dirt. The clock is working great all day (I picked it up this morning), but I've noticed the chime goes off about 1 minute / half a minute earlier than the minute hand reaches the hour or half hour. Is this within an expected tolerance, or should it be exact?
    I reassembled everything myself (as in putting the movement back in the casing, reattaching the pendulum, putting the face back on, putting the hands back on). He had taken apart, oiled and reassembled the movement, so I didn't touch that other than putting it back in the casing and putting the hands back on.
    The minute hand mounts on a square spindle and the hand has a square hole, so there is a little bit of play in the hand on the spindle which I can't really take the slack out of...?
    Cheers! :)
  47. Bruce Alexander
    Feb 22, 2010
    6,016
    366
    Some discrepancy is not unusual. As you've noted there is a little bit of "play" in the parts involved.
    Try flipping the minute hand so that the surface which is facing the dial is now facing away from it. See if it makes a difference.
  48. Uhralt
    4,045
    413
    This is about what you can expect. If it bothers you, you can try to turn the minute hand around. If that doesn't make a difference, you can try to close the square a bit by hammering around it with a punch. Don't overdo it or the square might become too small. Punch, test, repeat as necessary.
  49. Darkstrike
    Aug 4, 2019
    20
    Hi all - my clock has been working great since I had it serviced, however...one thing is odd for me.
    Before I had it serviced when I had run it for a day and for a sporadic hour or two just to see if it was working correctly (if you remember, when I was first given it, I was told it was broken), the chime worked fine. It does now since the service, but the odd part is this:
    Before the service, say, if the chime went off for 5pm, I would hear 'ding...ding...ding...ding...ding' - all is good, it was nice and even, went off on time, etc.
    Now, since the service, it does chime at the appropriate time (maybe 30 seconds to a minute before the minute hand actually reaches the right time, as I mentioned in my previous posts...this doesn't bother me, really)...but the chime is uneven, as in (for 5pm) 'ding...ding...........ding...ding............ding'
    ...if that makes sense. I thought maybe it gets like that when run down (and that could just be my issue?) but when I go to wind it, the winder for the strike train seems a bit stiffer than I remember, as if it's already fairly wound?
    Thoughts? Sorry for all the newbie questions! :)
  50. Uhralt
    4,045
    413
    Check if, when the clock has stopped striking, the lever for the strike hammer is between two pins of the pinwheel and not resting on one.
