Recommended Heat Gun
Jim_Miller
Mar 6, 2001
929
22
75
Jackson, Michigan
i find myself in the possible need of a heat gun. I’ve heard a lot of you folks talk about using them, so are there any recommendations? Any suggestions on what I should look for, the pros & cons?
Any info is appreciated,
Jim
David S
Dec 18, 2011
7,172
271
Brockville, On Canada
Jim,
My experience would indicate that having variable heat seating and variable fan speed is very beneficial. The one that I have is a Porter Cable.
David
wefalck
Mar 29, 2011
846
156
Paris
I gather the answer depends on the intended use, determining the amount of heat to be delivered at what temperature. When you say 'heat-gun', do you envisage one of those gun-shaped thingies that is typically used to strip paint ? Or did you think of a small hot air-soldering station ?
For soldering, pre-heating, blueing and tempering I use one of those cheapo Chinese hot-air soldering stations like this:
Its temperature range is 100°C to 450°C and the air-flow can also be regulated. They cost around 40€ on ebay et al.
There are also monile hot-air soldering pens, which are essentially a torch that heats the air-flow, rather than directing the flame to the soldering joint, for contactless soldering. They usually also come with soldering tips.
Jim_Miller
Mar 6, 2001
929
22
75
Jackson, Michigan
Welfack, thanks for your info. Yes, my choice is a pistol grip type. I do case and furniture refinishing as well clock repair.
Thanks,
Jim
Staff online
181,468
1,583,414
54,824
MdmSaturnia
3,131
Swiss Fake by Kent
Top
