Recommend a micrometer
Discussion in 'Clock Repair' started by POWERSTROKE, Mar 8, 2020.
  1. POWERSTROKE
    POWERSTROKE Registered User
    Jan 11, 2011
    849
    56
    #1 POWERSTROKE, Mar 8, 2020
    Preferably affordable and from amazon. I usually use go-no go method. But I like to just use this for ordering bushings I don’t already have.
    And offhand in the meantime. does anyone know what the diameter of a baduf 2nd wheel pivot is on average About? It’s less than 1mm because that’s the smallest I have.
  2. Simon Holt
    Simon Holt Registered User
    Mar 21, 2017
    475
    60
    Shaftesbury, UK
    Look for Digital Caliper rather than Micrometer. They all look so similar they are probably made by the same factory and the cheapest ones are very cheap. I use one all the time when checking pivot size and they are more than accurate enough.
    Simon
  3. JTD
    JTD Registered User
    Sep 27, 2005
    7,233
    440
    I bought mine from Lidl supermarket. Cost very little and works fine.
    JTD
  4. Vernon
    Vernon Registered User
    NAWCC Member Sponsor
    Dec 9, 2006
    650
    62
    Gardener/Arborist
    I use my digital caliper all of the time for everything. Think that I bought mine at Harbor Freight for $18 so not top of the line for sure but has served me well. My micrometer was a gift and is only used to to check pivot evenness (parallel) only.
  5. Altashot
    Altashot Registered User
    Oct 12, 2017
    141
    31
    I can’t recommend a cheap measuring device. If you want something that’ll last, that takes accurate measurements with repeatability, I’d opt for a Mitutoyo.
    Caliper or micrometer. I prefer the former. If you choose the micrometer, make sure it has a clutch or ratchet or thimble stop or whatever they call it for repeatability. It prevents over tightening.
    I’ve had a cheap $59.99 calliper that gave me nothing but trouble. The finish on it was not good, burrs, parallelism, as well as repeatability issues made it useless for clockmaking. Good enough for the garage but not for my horological shop
    Just my opinion.
    M.
    Jerry Kieffer, gmorse and dad1891 like this.
  6. shutterbug
    42,727
    1,114
    Ball bearing ends will increase your accuracy on things like mainspring thickness. Worth the extra $
  7. Bruce Alexander
    Sponsor NAWCC Brass Member
    Feb 22, 2010
    6,627
    567
    You know the general rule about tools I'm sure. Buy the best you can afford and save money in the long run. I like the digital with instant conversion between metric and imperial but they tend to be cheaply made and changing the button battery can be a pain.
    If you think you'll be fabricating parts, get something as accurate as you can afford. If you just need it to size pivots for bushings, something accurate to a tenth of a millimeter will get you close. Your broaches will do the rest. Metal work requires accurate measurements.
    Altashot and POWERSTROKE like this.
  8. bruce linde
    bruce linde Technical Admin
    6,336
    691
    oakland, ca.
    what other bruce said... i use mine primarily for bushings, etc... and occasional but light lathe stuff. i am not making precision parts.
  9. POWERSTROKE
    Jan 11, 2011
    849
    56
    Thanks guys!
  10. glenhead
    glenhead Registered User
    Nov 15, 2009
    1,110
    154
    Telecom Engineer
    Williamson County, Texas
    In answer to your question, here's a micrometer available on Amazon that will get the job done without breaking the bank. https://www.amazon.com/General-Tools-001-Inch-Graduation-Micrometer/dp/B00004T7UD/ref=sr_1_7?keywords=micrometer&qid=1583704262&sr=8-7 It has the more-important features - a ratchet to use until you develop the feel of how to use a micrometer and the zero point is adjustable. Sure, you can spend five to twenty times the money for a Starrett or Mitutoyo. They'll do the same job. From my experience the really-expensive micrometers might be smoother or have a better finish, but my dirt-cheap micrometers are just as repeatable as my Mitutoyo (which was a gift).
    If you also want a digital calipers (both tools have their uses) then again, the really-expensive ones might have benefits, but a decent inexpensive one like the one Bruce recommended can be just as repeatable and get the job done.
    I use a micrometer nearly all the time for diameters, calipers for things a micrometer doesn't measure or for a quick non-critical measurement. (Hole diameters and depths, lengths of things, arbor diameter to choose rod stock, etc.) That's my approach.
    If you decide that super-precision machining is your gig you can drop the money on really expensive ones once the money starts coming in.
    Hope this helps.
    Glen
  11. Kevin W.
    Kevin W. Registered User
    22,248
    311
    I am old school. I buy good and not cheap. Have had experience with cheap measuring tools at work in a machine shop. Go with Starret, Mititoyo. Cost more last a very long time when cared for.
  12. Willie X
    Willie X Registered User
    12,774
    982
    I like the Starret brand. Good products at a reasonable price. I can get the Starret number tomorrow, I keep a spare, and still have one in the box.
    My 'go-to' verneer caliper is an old Craftsman. It's beat up and the glass is cracked and the bezel clamp is broken but it still works like a charm. It has a much better 'feel' than newer ones.
    I only use mechanical calipers. They won't suddenly die on you and you can easily split a thou with a good dial caliper.
    Kevin W. likes this.
  13. Chris D
    Chris D Registered User
    Sep 8, 2009
    460
    17
    Coplay, PA
    For deciding what bushing to use, if you can afford it, this is great! KWM Pivot Gauge
  14. Kevin W.
    22,248
    311
    We had a Fowler vernier calliper at work. What a piece of junk, lasted about 2 months.
  15. glenhead
    Nov 15, 2009
    1,110
    154
    Telecom Engineer
    With respect:
    High-end measuring devices are great if you're creating something from a drawing, or if you're measuring an item so that someone else can replicate the item as accurately as possible using another measuring device. For the vast majority of repair work, there's no need to let "best be the enemy of good". The primary thing you need to look for is repeatability. If you have a micrometer that measures a diameter a 0.637", it's way more important that the same micrometer get the same reading at the same point if you measure again. It's not particularly important whether the measurement is 0.636" or 0.638" if all you want to do is match the diameter of an existing pivot. Which is really more important: being able to measure and match the diameter of a broken pivot or being able to say "wow, I have a Starrett"? If you can't afford a Starrett or Mitutoyo for repair work but you can afford an inexpensive micrometer with great repeatability, then in my book it makes more sense to get the repeatable inexpensive one and move on. Frankly, what the inexpensive one measures isn't particularly important, as long as it lands at the same spot every time. Maybe you can get the fancy one when the inexpensive one has made you enough money in the interim.
    I understand about calipers having issues with repeatability. That's why I use a micrometer - repeatability.
    Just my opinion.
    Glen
    David S and JTD like this.
  16. tom427cid
    tom427cid Registered User
    Mar 23, 2009
    1,617
    86
    Cabinetmaker,clock repair
    Moultonborough,NH
    I might add that measuring SS for 400 day clocks the only way to go is a vernier micrometer. Dial calipers just don't measure up! (pun intended)
    Also look for Brown and Sharp,their tools were as good as Starrett (the older models)
    Hope this helps.
    tom
