Rebushing an already rebushed pivot hole would seem to be a fairly common clock repair procedure but I haven't found anything written up about how to do it. The bushing I need to replace is size L17, which uses a size III reamer, so I would have expected there would be some bushings with the same I.D. and the next bigger sized reamer IV. None of the bushing charts I have found indicate such a bushing exists. Do I have to lathe my own? How would you re-rebush this pivot hole?
Thanks for sharing whatever experience you may have had with this challenge.
