Help Reassembling Keebler Lux Novelty Clock
KellyC
May 15, 2022
10
58
NE Wyoming
Hello!
When disassembling a Keebler Lux clock for cleaning, the zip tie I had around the spring was not sufficient for the job and it flew apart before I could take pics for reassembly. Most of it is quite intuitive, except for this mini gear. I've searched for info, but no luck. Anyone know where this goes? (ignore the other part in the pic - I posted about that in the Parts Wanted section).
Thank you,
Kelly
EscapeWheel
Mar 19, 2003
1,028
275
This my Lux clock. It might be sightly different from yours, but there is a small gear on the front side of the movement. Hopefully you can see it in the picture? When your spring let loose, it might have knocked it off.
About the other part - it may be possible to cut off the broken pivot, drill a hole and insert a wire to remake the pivot. You'd need a very small drill bit and Dremel or something similar (unless you have a lathe).
Ken X
May 10, 2021
64
33
59
My small lux clock has a wheel similar to that located on the minute arbour, outside the front plate. It drives the hour cannon reduction wheels. I may have a photo on file and will look it out.
KellyC
May 15, 2022
10
58
NE Wyoming
Thank you both so much! That's exactly where it goes!
re the other part, I think that skill set level is currently beyond me.
Thanks again! This post can be marked solved (but not sure if I can do it...)
Kelly
EscapeWheel
Mar 19, 2003
1,028
275
Fantastic! Glad we could help.
These clocks are surprisingly well made for what they are - and fun to watch.
I still think you could repair the other part, but you could also check the auction sites for a basket case to use for parts.
183,860
1,605,832
55,918
Haydee
3,190
Watch case by Kent
Top Bottom
