I'm working on an unsigned time-only Vienna. The clock was running when I disassembled it. Checking it over, some of the pivots have a fair amount of wear - a couple have a fairly significant groove in them. Normally I would polish that out and rebush the movement, however the pivots are already microscopic - 0.5mm. I'm fairly comfortable with larger movements, but this is my first foray into something this small. I've also heard that often Viennas have hardened pivots. Would that likely be the case with this clock (I'm assuming no since they're so worn)?
What's the best path forward? grinding down the existing pivot and repivoting with new wire perhaps slightly larger than the original pivot size to compensate for plate wear? Should I try polishing? If so, how small is too small?
Thanks in advance for any advice.
