Re-silvering a Jacques Tall case clock face
Discussion in 'Reverse Glass and Dial Painting' started by dgoerner, Jul 22, 2019.
Tags:
  1. dgoerner
    dgoerner Registered User
    Mar 12, 2010
    87
    12
    NJ
    Hello All
    I have been working on this clock for a while now, maybe someone can tell me what I have done wrong
    I wet sanded the face and then used the wax/shellac stick from timesavers to fill in the black, re-sanded, then silvered, I was proud of my work, then after a couple of hours, I cleared the face using a wipe on lacquer made by watco.
    what a mess the black started to streak and even some came out. What did I do wrong?
  2. FDelGreco
    FDelGreco Registered User
    NAWCC Star Fellow NAWCC Member Sponsor
    Aug 28, 2000
    1,885
    52
    Retired chemical engineer
    Novelty, OH
    The lacquer dissolved the wax. If you lacquer, you must use a light spray or wipe only once and lightly if using liquid. Many restorers just use a paste wax. The wax will last for years, and you can always rewax.
    Frank
  3. dgoerner
    Mar 12, 2010
    87
    12
    NJ
    Thanks Frank that must be it when I wiped it, then I re-wiped it the second time, and what a mess. I just wanted to weep, now I start all over again.
    I will use wax this time, your right I can wax it again. I was so proud my first re-silver and I was so careful.
  4. novicetimekeeper
    Jul 26, 2015
    9,285
    488
    Dorset
    modern wax seems to struggle a bit with lacquer. Renaissance wax seems to be the solution.
  5. Uhralt
    Uhralt Registered User
    4,030
    413
    If you want to use lacquer, use a fast drying spray, do not brush it on. As Frank said, only a light initial spray. Let it dry and follow up with one or two more sprays.
  6. dgoerner
    Mar 12, 2010
    87
    12
    NJ
    Thanks Uhralt, your opinion would you use a gloss?
