Re-Bush question.
POWERSTROKE
Jan 11, 2011
1,116
74
I have a movement in front of me that has what seems to be a 1mm inner diameter and 2.7mm outer diameter bushing in it. This should’ve had a .8 or .9 id bushing installed. Now that the hole is reamed to 2.7, how will I be able to correct this? The 1mm Id seems to have too much play for my taste....
Vernon
Dec 9, 2006
961
120
Take a punch smaller than the od and give it a few blows from either side. You may need to open it with a broach. Not a great solution but since you hand bush, maybe your only.
POWERSTROKE
Jan 11, 2011
1,116
74
What other options are there? Is it not possible to get a small ID bushing with a 2.7od?
Vernon
Dec 9, 2006
961
120
You may be able to put a proper sized bushing within your bushing. The best way would be to remove the one you installed and put in a blank, then drill the proper size but that requires a mill or lathe.
46,112
1,757
You can do a bushing in a bushing when needed. You'll have to go with a first bushing large enough to accommodate the second one, and then do the second one slowly so as not to pop the first one out prematurely.
Reactions: POWERSTROKE
Bruce Alexander
NAWCC Brass Member
Feb 22, 2010
7,326
774
If you place a bushing within another bushing, I recommend that you use some type of retaining compound on both of them. Personally I like Loctite 680.
164,707
1,432,947
85,757
akrampe64
2,863
