Ratchet Wheel Screw: Always Reversed From Direction Of Turn?
Discussion in 'Watch Repair' started by everydaycats, Nov 30, 2014.
  1. everydaycats
    everydaycats Registered User
    Aug 11, 2011
    457
    Mexico Beach, FL
    As a rule-of-thumb will the ratchet wheel screw always be reverse threaded from the direction of wheel turn? Assuming a single screw...
  2. cbaron
    cbaron Registered User
    Jan 19, 2012
    93
    Jersey City, NJ
  3. richiec
    richiec Registered User
    Feb 24, 2007
    6,802
    593
    automotive warranty inspector
    Brick, Ocean, NJ
    I know from my limited experience that Waltham rarely uses a left hand thread on its ratchet wheels but Elgin does.
  4. doug sinclair
    doug sinclair Registered User
    Aug 27, 2000
    14,364
    58
    Calgary, Alberta
    Certainly, some watches use a left-handed screw on the ratchet wheel. Most watches with exposed winding wheels use a left-hand thread on the crown wheel screw. Once in a while, a crown wheel screw will have three screw driver slots, OR and extra notch radially cut into the edge of the screw head. These will be left-hand thread. But you may run into such a screw on the ratchet wheel as well. But once in a while, you may run into a watch with the crown wheel and ratchet wheel under the barrel bridge. If and when you do, the ratchet wheel screw is right hand thread 99.9% of the time. If a crown wheel has a core (hub) held in place with two screws, these will be right-hand thread.
  5. Jerry Treiman
    Jerry Treiman Registered User
    Aug 25, 2000
    6,370
    1,813
    Geologist - California Geological Survey
    Los Angeles, CA
    Richie - did you mean to say "crown wheel"?
  6. richiec
    Feb 24, 2007
    6,802
    593
    Brick, Ocean, NJ
    Whatever Jerry
  7. everydaycats
    Aug 11, 2011
    457
    Mexico Beach, FL
    #7 everydaycats, Nov 30, 2014
    Crown wheel...my mistake. cbaron and Doug pretty much covered the bases above by describing the ratchet wheel and crown wheel...
  8. Skutt50
    Skutt50 Registered User
    Mar 14, 2008
    3,605
    142
    Gothenburg
    There seems to be a very simple explanation to why the crown wheel screw is left hand threaded.
    I have come across one or tow watches with a right hand threaded crown wheel screw but this was the result of earlier erroneous repairs. The result was that when winding the watch the crown wheel unscrewed the right hand threaded screw and the winding did not work!
  9. doug sinclair
    Aug 27, 2000
    14,364
    58
    Calgary, Alberta
    Some watches have a right hand thread on the crown wheel! Some 16-size Walthams for example. With these watches, once the crown wheel screw, crown wheel, crown wheel hub (core) are removed, under the crown wheel there is a steel spacer washer which is held in place with a small screw. If you flip the crown wheel hub over, you find a notch which fits over the small screw on the spacer washer. This prevents the crown wheel hub from turning, thereby preventing the crown wheel screw from loosening. There may be other watches with a similar arrangement.
  10. RJSoftware
    RJSoftware Registered User
    Apr 15, 2005
    8,364
    87
    Loxahatchee, Florida
    Some of the Bulovas are right hand. The cheap mass produced one I think. Caravel, I think... I definitely remember busting one cause I was sure it was suppose to be left hand.
    I know about the 3 slit identification. But I am not sure it always is done. Best test is a small tweak in one direction and then a small tweak in the other. I do left first because that's what it should be.
    Least that is my experience. I hate forgetting.
    RJ
  11. everydaycats
    Aug 11, 2011
    457
    Mexico Beach, FL
    I knew about the three-line marks in industrial applications, but never seen it used in watches...I was at my brothers place of work a few years ago which was a huge industrial plant with huge machines. Two of his workers were trying to loosen a large bolt, but it would not budge. I happen to see three engraved marks next to where the bolt was and I mentioned to my brother that I had heard those marks indicated reverse threads, and once they applied force opposite to what they thought was correct the bolt broke loose. But, that bolt had a head probably close to two inches in diameter. Again, in my very limited experience I've never seen it in a watch.
  12. Al J
    Al J Registered User
    Jul 21, 2009
    615
    71
    Crown wheel screws are left handed, except when they aren't. Left hand threaded screws have 3 slots in them, except when they don't. That pretty much sums it up. :)
    Cheers, Al
  13. everydaycats
    Aug 11, 2011
    457
    Mexico Beach, FL
    :cool::thumb::clap:
  14. watchwldr940
    watchwldr940 Registered User
    Nov 26, 2008
    398
    20
    To add a bit-- the Font 60 (I believe) has a left handed ratchet wheel screw. Why, I don't know, but over the years I've accumulated a bunch of these movements with the screw broken off. When in doubt, apply gentle pressure first in one direction, then the other until it loosens. These movements have no indication that this screw is left handed so they are often broken. George
  15. everydaycats
    Aug 11, 2011
    457
    Mexico Beach, FL
    I ran across this picture today while browsing in the swamp and I noticed the three lines. I assume this is a properly marked reversed threaded screw. This is the first time I have seen this:
  16. Samantha
    Samantha Registered User
    Jun 28, 2009
    912
    17
    Female
    Watchmaker
    Central Florida
    Yes, that is a properly marked reverse threaded screw.
    Samantha
  17. Firegriff
    Firegriff Registered User
    Feb 22, 2013
    756
    Screws/nuts on counter shafts usually have threads opposite of the driven shaft so wont loosen the screw/nut on the counter shaft.
